Results 1 to 15 of 16
Thread: ERG vale tube
    BoiseHemi's Avatar
    BoiseHemi is offline KravMagaSpokane.com
    Spokane, WA
    ERG vale tube
    Is the ERG valve tube that comes off the passenger side of the intake manifold called "ERG valve"? I need to get a new one and want to know what to ask for. Thanks!
    05 R/T:Frank racing econo heads: milled, PP for N20 & Sidewinder cam w/custom push rods, 2 1/2" custom Borla pro, JBA headers & high flow mids, Modified Volant intake, Custom Diablo tune, Cross drilled and vented rotors, MHT custom caliper covers, BT Catch Can, Zex Kit, NoESp., Functional Mopower shaker, Kenwood in dash DVD w/ backup cam.
    MikeEast's Avatar
    MikeEast is offline No longer sporting dual R/T's!
    Ducktown, Georgia
    The 'hot' one with the shiny stuff around part of it is indeed the EGR tube.
    Mike
    BoiseHemi's Avatar
    Spokane, WA
    Sweet....where would be the best place to get a used one?
    Z06Yell's Avatar
    Z06Yell is offline LX Padiwan
    Jun 2007
    NC
    Quote Originally Posted by BoiseHemi View Post
    I had to buy a new one also. I would suggest to just go to the dealership, I could not find a used one anywhere (all of the junk yards keep them with the engine). They are fairly cheap, I think I paid $15 for it brand new. The only problem is that they are on back order, I had to wait about 10 days for mine.
    BoiseHemi's Avatar
    Spokane, WA
    Quote Originally Posted by Z06Yell View Post
    Thanks....did you check with cleveland pick-a-part? I will call the dealer tomorrow. Why did you replace yours?
    InferAl's Avatar
    InferAl is offline "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    What was going on with it to let you know you need a new one ?
    Video
    BoiseHemi's Avatar
    Spokane, WA
    I trimmed it down where it goes into the intake manifold.....via Mom's suggestion for my idle problem. Anyway I cut it down too far....rookie mistake...and now have a small leak. For what it is worth the car is not dying anymore....at least not yet.
    Z06Yell's Avatar
    Jun 2007
    NC
    The magnum I purchased had the EGR tube removed, but I had to replace it because NC has the OBD II emissions testing. I did ask Cleveland pick-a-part, and they told me the tubes go with the Hemi drop out engines.
    Boggus's Avatar
    Boggus is offline The HEMI pit
    Big Ole TEXAS
    Does it throw codes if you no longer have it running into the TB?
    MomsR/T's Avatar
    MomsR/T is offline Builders of the 500rwhp 426's
    Houston
    BoiseHemi's Avatar
    Spokane, WA
    Got one coming from the dealer $15 and the rubber bushing is $5.
    Carfinish's Avatar
    Carfinish is offline Capeeesh!?
    Nov 2005
    New York
    Quote Originally Posted by MomsR/T View Post
    yes.......but we cut ours down to move it out of the flow path
    Lee what's this for ....just curious....where was cut and which flow path???
    RIP
    12.869 @ 102.02 Stock 5.7 w/ C&L, Predator, JBA Cats, Volant catback, 3.06 Getrag, DRs & skinnies
    BoiseHemi's Avatar
    Spokane, WA
    I was having a problem with not getting enough air and was dying at lights. I cleaned up the butterfly valve and trimmed the ERG down as recommended by Lee. He said that this was done in other cars with this problem, by trimming it down you allow more air to go in. If you have your CAI off flip down the butterfly valve and you will see it goes in the intake quite a ways....I was really surprised how far it was. I figured it was just inside enough to get the air it needed not halfway in the intake.
    IMO it just blocks and disrupts the flow of air....anyway I am sure Lee has a better explanation...either way the car is idling great now. Later
    Carfinish's Avatar
    Nov 2005
    New York
    ok I understand now....never seen it inside...I'll take a peak one day...thanks
    InferAl's Avatar
    Nov 2006
    NE Ohio
    Did you have to take it out and saw part off
