Results 1 to 15 of 23
    wildwilers's Avatar
    wildwilers is offline Been AMP`d
    Aug 2008
    North Fla
    EGR Delete Problems for 08 W/Predator?
    Just got off the phone with diablo and they said for the 08 models you need a custom
    tune to turn off the egr.Have any of you 08 people had this problem?Dont want to go take it off and have to put it back on!!!
    6.1L CRATE W/ 3:06 GETRAG 08 R/T
    diablotoona's Avatar
    diablotoona is offline NOOB....
    Jun 2007
    Delray Beach, FL
    Huh, thats a parameter in the current predator and has been there for a while.
    Who did you speak to here so i can inform them.
    Johan <at> diablosport.com
    DiabloSport R&D
    Only two things are infinite, the universe and human stupidity, I am not sure about the former.
    wildwilers's Avatar
    Aug 2008
    North Fla
    i wish i knew the techs name but justin at franks racing warned me that he had a few problems with some cars but did not mention their model yr.The tech said i would need a special tune??He did not tell me his name!Is this a problem for the 08`s?I know you will steer me in the right direction!
    Jun 2007
    Delray Beach, FL
    I have not heard of any issues with egr delete on any year, all it is in the software is a switch that tells the pcm if it is equipped with egr or not, same for all years.
    DiabloSport R&D
    wildwilers's Avatar
    Aug 2008
    North Fla
    Johan, what tune would you recommend i install with the mods i have?
    Popeye's Hemi's Avatar
    Feb 2008
    Eastern Shore of Maryland
    Quote Originally Posted by wildwilers View Post
    All you have are Catback and Air Hammer, then put the 91 or 93 CAI tune in. Use the best 93 octane gas you can find and data log for LT-KNK and ST-KNK. The only real differences in the two tunes are the amount of spark and fuel delivered at WOT. Torque management is reduced in both of them. I would remember to reset all parameters when changing out the tunes and possibly pull fuse #2 in the front fuse box to reset the adaptives. Drive the car like you stole it and see what that does for you. Do you have a Jet 180 Thermostat? If so use the fan settings that come in the tunes or set all High fan speeds to 188.xx Medium to 188.xx and low speed fans to 178.xx
    Good luck and keep her between the ditches.
    Jun 2007
    Delray Beach, FL
    ^^what he said...
    DiabloSport R&D
    wildwilers's Avatar
    Aug 2008
    North Fla
    Thanks very much popeye, i dont have the 180 yet but will soon.My main concern right now is to
    get rid of the EGR tube and motor!
    Feb 2008
    Billet Tech is a vendor here in the vendor aisle and they sell an EGR Delete kit that works good. remember that the diablo marks the MDS system for turning it off when you use it to disable the egr system.
    wildwilers's Avatar
    Aug 2008
    North Fla
    i have that kit.One last question before i go install,is it better to install the tune first and then go back and modify it and reinstall?Or just modify the tune first and then install?Thanks for the help
    05nvrL8's Avatar
    05nvrL8 is offline ANTI-RICE
    Feb 2009
    San Antonio/TSTC Waco, TX
    why would you remove the egr??? its there to help your motor and reduce emissions... it is almost never on and it's a $10,000 fine for removing it!
    2005 Dodge MAGNUM RT 13.8 1/4, 100.7mph trap (gone... for now)
    1974 Plymouth Duster, daily...
    slow engine
    slow transmission
    slow wheels
    wildwilers's Avatar
    Aug 2008
    North Fla
    Quote Originally Posted by 05nvrL8 View Post
    I will let Johan or Popeye answer that.For me it has to go for my next mod an 6.1 intake.
    Also in the way of my catch can hoses!!!We dont have emissions test in Fla. so i dont worry about it.
    Feb 2008
    When you install the tune it should ask if you want to modify the tune and then reset the parameters. Then pull the fuse for 30 seconds.
    As for the emissions and deleting the egr that is owner's choice and if you are worried about it, don't do it. For those of us that have put a performance cam in I look at it this way the stock SRT8 cam was spec'd to eliminate the need for an EGR system. A cam can be spec'd to do the same as an EGR system.
    wildwilers's Avatar
    Aug 2008
    North Fla
    Well after a morning of worrying that i was going to have problems i went ahead and took a dive and everything went as smooth as glass!!!!!!I want to take my hat off to Johan and Popeye for helping!!!!
    After all i have heard of Diablo well it is TRUE!!!If you are thinking about one GET IT!!!!!!!
    Jun 2007
    Delray Beach, FL
    Nother one bites the dust...
    On a serious note, we will most likely remove the EGR delete option and rear 02 delete in the next revision due to more stringent regulations from EPA, we want to stay in business and continue to serve you guys. It will always be a custom tune option though.
    DiabloSport R&D
