Originally Posted by
300C4ME
05MagnumRT,
Do you know any of the specifics in terms of the type of input or information the dealership fed your car to cure its ailment?
Unfortunately, I do not. They (service guys at my dealer) are willing to work on the car with aftermarket stuff and work with you in doing things, but they are not open to letting you INTO the work area or letting you touch their toys :( The good news is that as long as you have the extensions all connected well, you won't have the problems that I had.
Tedman5
Just out of curiosity, is the first step of installation disconnecting the neg terminal on the battery? I would imagine that this would matter since the current still flows through the car even when its off. When you disconnected the stock sensor leads, it may have picked up a malfunction in the system that was not easily reversed.
I think I am going to disconnect mine. Everything else I've put on, air intake, TB spacer, Jetchip module all had it listed as the first step so the computer can reset itself to new parameters.
Makes you wonder...... :idea:
We did not disconnect the battery when we did aspendog's, but we did when we did mine. It seems that the starter is positioned a little differently on a 300 versus a Magnum, or maybe on a May built car versus an October built car... I don't think disconnecting versus not had any real effect on my problems, though.
We also noticed that on aspendog's car, the heat shield on the passenger side was difficult to remove, on mine the driver side was a little more so than on his, but my passenger side was easy. Again, not sure if it's a 300 / Mag difference or a May / October difference.
