Results 1 to 15 of 17
    jerryrmd is offline LX Newbie
    Does the spark plug non fouler mod work to pass emissions?
    I just read a write up on Charger forums on how to pass emissions with no cats; the spark plug fouler mod.....has anyone used this successfully? It looks pretty easy and inexpensive and I would like to try it this weekend. Thanks for your input.
    Hemi31's Avatar
    Plattsburgh,NY/Lorain Oh
    What you didn't believe me over there?Whether it works or not depends on the car.....but like I said over there it's your only hope.It's either try it or put the cats back on.......If I were you I'd spend the $6 and try it.
    RIP NHDave
    I believe it worked for your car; I just wanted to hear how many people have had it work and how many have not. It's a great idea and I am going to try it out like I said; was just hoping I could get a percentage.
    How much steel wool did you use? I know you said to stuff it medium packness so did you cut it up and shove it in the hole?
    Mymopar's Avatar
    Mymopar is offline Punishing the competition
    New England - CT
    Have you picked up the anit-fouler yet? The purpose of this is to limit the air flow. Too much air flow and the sensor thinks there is a hole in the cat and throws a code. Too little airflow and the sensor thinks the cat is plugged up and throws a code.
    So basically you need to experiment to find a happy medium. I used 2 anti foulers together to make it work for me BTW. Depending on your mods and amount of airflow will determine how much steel wool to use. I didn't use any, I just used 2 anti foulers and drilled the hole different sizes.
    426 Power Ported Stroker, 3.06 getrag rear, 3600 FTI stall, Eagle Ported heads w/custom valves, ported TB, SLP long tubes, Silver Box, TZ Chally hood, custom BT, KW V2 Coilovers, Hotchkis sways and custom fabbed End Links
    1969 (oo===]|[===oo)
    2008 (O.|||||||.O) 2006 (Oo.|==+==|.oO)
    Super T's Avatar
    Aurora, IL
    I need to do this sometime this year, but haven't yet. There's no easy universal method and no guarantee it'll work on your car, unfortunately.
    Thanks for the input; I will try that if the first attempt doesn't work.
    mikespy's Avatar
    mikespy is offline Fastest N/A 5.7L Magnum around!!! SOLD!
    Houston
    Try it like Hemi31 told ya.... It worked like a charm for me and have been thru many emissions tests..
    2010 SRT8 Challenger...
    MODS: Magnaflow Competition exhaust, Roto-Fab CAI.....
    Hemi31's Avatar
    Quote Originally Posted by Mymopar View Post
    The steel wool isn't to slow down the flow.....it's to simulate the catalyst he no longer has,which is why it needs to be Stainless Steel.
    Ok, I went out and bought all the stuff but they had multiple grades of steel wool ranging from course to super fine; I bought the stuff in the middle called very fine......is this what you used or do you think it matters?
    Hemi31's Avatar
    Quote Originally Posted by jerryrmd View Post
    it doesn't matter as long as it's STAINLESS STEEL WOOL
    Not good; I think I just bought regular steel wool; it's from Rhodes American and just says steel wool; where can I find stainless steel wool?
    Hemi31's Avatar
    mjr5150's Avatar
    mjr5150 is offline Just Blown
    May 2006
    Long Island , NY
    Absolutely . Two years in a row now . A little reset drive and you are out of not ready status and golden .
    06 CSRT-8 Silver Steel (all opts.): MagnaCharger MP2300 TVS Supercharger, Hemituner tuned, Hemi Shop P & P heads , FRI Tomahawk cam , Dynatech LT headers,Corsa cat-back,Magnaflow HF cats,LMI CF True 4'' fendermount CAI , PT 3400 stall TC , Getrag LSD 3.06 rear, Paramount rebuilt tranny & valve body , Arrington 85MM Ported TB tapped for Nitrous , BT catch can ,Hotchkis front & rear sways ,15% tint all around,SRT-8 embroidered mats(biggest HP gain ).Future wants:Arrington 392 & an understanding(ok heavily medicated)wife..lol .
    PB 11.25 @ 125.16 - Stock Bottom 6.1L blown (10lbs boost)
    How about if I am only going to use the steel wool just to get past emissions and then pull it out; do I still need stainless?
