Results 1 to 15 of 16
    Mr 5.7's Avatar
    Mr 5.7 is offline LX Newbie
    Mar 2010
    AZ
    Diablo 93 CAI Tune but only 91 octane in the area
    Has anyone heard or tried to use 91 Octane with octane booster on a 93 CAI diablo tune just wondering because i have no 93 Octane here in Arizona where i live at and i have to wait on my predator to arrive with my household goods and they saying it want be here until december and i don't want to be stuck at home and cant drive for another month or so? Help
    2006 Magnum's Avatar
    2006 Magnum is offline Magnum Love
    Dec 2008
    Willowick, Ohio
    Prob wont hurt, I would change that asap though
    08300's Avatar
    08300 is offline LX Newbie
    Oct 2011
    You can pick up an octane booster to add to your gas from any automotive store. That will get you the octane you need. Most of those octane additives say how much to add to how many gallons to get your gas to the desired octane.
    Narc300C's Avatar
    Narc300C is offline Tic Tic Boom!
    Feb 2008
    Boca Raton, FL
    I would run 91 octane with the 91 tune. You dont want to keep adding octane booster to your ride.
    08300's Avatar
    Oct 2011
    Quote Originally Posted by Frank@Diablosport View Post
    As long as your octane is not low enough to cause pre-ignition, your good to go. Adding a booster to achieve 93 octane is no worse/different than running pump bought 93 octane fuel.
    Reality is as long as you have no pre-ignition you won't damage anything regardless of how you get there.
    Narc300C's Avatar
    Feb 2008
    Boca Raton, FL
    Quote Originally Posted by 08300 View Post
    How are you guarantying that you will get 93 octane by pouring in a bottle of octane booster? I see them on the shelf ALL the time, 103 108 octane booster, if you put that in your car, do you really think your running 103 or 108 octane??
    If your in a jam, and can only find 87 octane and you have a 93 tune in your car, sure, a bottle of octane booster will help you out, but to run a bottle of booster just to run it, I would stick to a 91 tune.
    jojotunes is offline LX Padiwan
    Jul 2010
    Keep the RPM's up as the damage is caused when the motor is under load
    08300's Avatar
    Oct 2011
    Mr 5.7 is looking for a month long fix, an octane booster will do the trick. Fact. Quit being argumentative and read the entire post.
    For example, no one has guaranteed anything, especially what the final octane rating might be. A bottle of booster will easily get the fuel above 93 from 91 octane. There's no risk here from running a 93 tune with 93+ octane for a short term. As long as you have no pre-ignition, giv'er.
    Narc300C's Avatar
    Feb 2008
    Boca Raton, FL
    Umm who is arguing? If you think a bottle of octane booster is the fix, by all means have it at. Like I said, if your stuck, your stuck, but I wouldnt do it on the norm.
    Quick's Avatar
    Quick is online now LX Newbie
    The car will pull timing as needed (knock retard) up to a point. As long as you're under that max you don't need to worry about it. ...haha, I guess you might need your predator to log though . I seriously doubt you're going to max out on knr running the 93 tune on 91 gas.
    I'm assuming you have a 5.7L. Max knock retard pulled (different for different RPM ranges) is:
    Stock 5.7L
    RPM - max deg pulled (ST and LT combined)
    6000 - 5*
    5200 - 7*
    4800 - 9*
    4000 - 10*
    3600 - 10*
    3000 - 12*
    2000 - 12*
    1200 - 15*
    600 - 15*
    smackdownsrt's Avatar
    smackdownsrt is offline LX Guru
    Nov 2010
    Why not just use the 91 CAI Tune?
    Quick's Avatar
    Quote Originally Posted by Mr 5.7 View Post
    Quote Originally Posted by smackdownsrt View Post
    His 91 CAI Tune is packed in the moving van somewhere.
    Mike@Diablosport's Avatar
    Mike@Diablosport is offline Supporting Vendor
    Jun 2007
    Ft. Lauderdale
    Easy answer is to not beat on it. Stay out of WOT situations.
    Octane booster is not going to help, save the $$$.
    Mr 5.7's Avatar
    Mar 2010
    AZ
    Yep Guys my Predator is in my household goods i want see it until middle of December!
    cleary524's Avatar
    cleary524 is offline Hemi Reg#1120
    Nov 2008
    Northwest, RI
    Just go easy on it and avoid WOT situations.
    2005 Magnum RT AWD 344AWHP/358AWTRQ
    FRI Sidewinder Cam, Johan Tune, Edelbrock Headers, JBA Hi-Flo Cats, Magnaflow Catback, 180* T-stat, aFe Stg II CAI, 85mm Throttle Body, SLP 25% UDP, Catch Can, Taylor Shortys, Freak351 Trans Box , Eibach Pro Kit Springs & R1's. Interior, Engine & "M" Emblems by Billet Tech, R/T Emblems, Magnum R/T Grille, Black Heads & Tails, Eyelids
