FWIW, you can run just about any of the newer designed hydraulic cam with 4°-6° of advance with NO loss in top-end performance, assuming adequate clearances can be achieved.
The CC607 cams is as follows:
duration I E
@0.006" 278° 284°
@0.050" 227° 233°
@0.200" 151° 156°
max lift .353 .353
LSA 116°
I recommend running it 4°-6° advance, for an ICL of 110°-112°.
This is an assymetrical cam, with a stiff opening, for lots of area under the curve, and a nice, gentle closing, to minimize the "Infamous Hemi Tick", lol.
It's rather large for a stock 5.7/6.1 engine, and will not have adequate P-2-V clearance with the stock pistons. It'll make a 426 stroker motor purrrrrrr like a kitten @ 700 idle rpm, and still break the 600hp mark.
I have smaller versions available, for stock displacement engines. I am especially impressed with the performance of my 6.1L "stock replacement" cam.
With headers and a slight tweak of the tune, and stock 6.1L valvetrain, it's showing a hair over 500hp on an otherwise stock 6.1L crate engine. How's that for "stock replacement"?
For that matter, a hemi cam with ANY duration, ANY lift, and ANY LSA is just a phone call away. I can even custom spec a cam for each individual application, if so desired.
