Coolit mod install problem
I received mine today and installed it per directions. I tested it and the horn doesn't beep and the fans don't go on after 3 or 4 switches from headlights off to parking lights on. Anyone here have a similar problem and know the fix. I also sent an e-mail to NoESP but don't know if they read their e-mails on the weekend.
Jeff
did you start the car first? if so,
you must have used the wrong relays or the wrong pin on the relays.
I rechecked the directions and picked the wrong relay for the parking lights. Duh! Thanks for reminding me to double check. Works great now.
Jeff
- You may not post replies
- You may not edit your posts
Forum Rules
