Results 1 to 11 of 11
Thread: Cam Ideas
    TMag's Avatar
    TMag is online now Mopar or Nocar
    Texas
    Cam Ideas
    I would like to know what is a good cam to go with, something just above stock for a 5.7L. I am going to upgrade the pcm to the Mopar PCM. Nothing to radical, something that will put out a little more than the stock one does.
    Thxs
    Mods- De-molded/Hood to Fender Stripe/Mopar Performance Intake/SRT8 Rear Deck Spoiler. Mods on Deck- Flowmaster Super 10's, Blastin Bob's GPSSR250 Pipes, Diablo InTune, MSRT Rims 20x9/Vred's 270/40/20 fronts, 315/35/20 rears.
    USCG Charger's Avatar
    USCG Charger is offline Inertia 383 Stroked
    Jan 2007
    prolly the Sidewinder from Franks!
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    cam only swap.....take a hard look at the Frank Racing "Sidewinder".......MDS and computer friendly!! Good torque cam, what these cars really need, and you keep everything else stock.....contact MomsR/T or Gremlinsteve on here and they can get you hooked up.
    moparman53's Avatar
    moparman53 is offline Finally got a HEMI again.
    Nov 2004
    E Williamson Co, Central Texas
    Either the Sidewinder or Comp XFI-260 or 268.
    lafrad's Avatar
    lafrad is offline Zomg.
    Feb 2004
    Muskego, WI
    The Comp 268 may be a turd if you don't do any modifications to the heads or intake, and it takes a good bit of effort to get it to idle and behave nicely in heavy traffic.
    The Comp 260 has been hit-or-miss for people, all did find more power, but some have had behavior problems with this one too... where it would stall when warm and such.... requiring a B&G flash of the computer or a piggyback fuel adjustment device.
    The Sidewinder from Franks Racing runs well on a Superchips flashed computer (from what has been shared), and will give you a good powerband with comparable power numbers to the Comp 260, but definately better "in town" behavior... no stalling, etc etc. This is probably the current "Bang for your buck" leader, drop it in and tear up the roads!
    bklynmag is online now Maggie under construction
    Brooklyn, N.Y.
    The sidewinder requires a valve spring change as well correct?
    lafrad's Avatar
    Feb 2004
    Muskego, WI
    Its not *necessary* for a valvespring change, but you probably should...
    FlyByU's Avatar
    FlyByU is offline MSHS
    May 2006
    Long Island, NY
    The sidewinder works with the jet chip too. Idles perfectly.
    JonzMgnm's Avatar
    Jan 2006
    Commack, New York
    .....umm....Sidewinder!
    John Y
    Jun 2006
    Houston, TX
    Quote Originally Posted by bklynmag View Post
    Not necessary, but some have been using the srt springs with it.
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    I would change the valvesprings for any aftermarket cam.Cheap Insurance!
    BFNY PERFORMANCE
    RIP My Friend
