Results 1 to 7 of 7
Thread: C&L Intake??
    HemiRedMagnum's Avatar
    HemiRedMagnum is offline LX Padiwan
    Mar 2008
    C&L Intake??
    Well I have a C&L intake and was reading about them getting really hot and I notice myself I was wondering about ceramic coating it? Would this help at all? Or does this only work to keep heat in?
    SHOULD I DITCH THE C&L FOR SOMETHING ELSE???? Opinions please! Thanks!
    07 Magnum R/T AWD
    Mods: Diablo,C&L Intake,180 T-Stat, Dual Magnaflows, Moe's Ported TB, PB Underdrive Pulley, TruFiber SRT Hood, custom gauge cluster, HF cats w/ E-cutous. FRI Sidewinder and JBA Shorties awaiting install!!!
    The Angry Goat is offline LX Newbie
    Jul 2009
    Sacramento CA
    I actually just went over this... It's actually a design flaw... and it's going to retian conductive heat from the Throttle Body anyways.. spend your money on something else.. I went Airraid.... it looks and performs well
    Mar 2008
    Bump
    07 Magnum R/T AWD
    Aug 2008
    no need, an intake is an intake, they all do the same and dont do much ontop of that
    SRT airbox, SRT headers/mids, SRT catback, SRT full suspension, BT 85mm TB, BT catch can, and email CMR from forgeinMuscle
    done's Avatar
    Old Hickory, TN
    Quote Originally Posted by street hooligan View Post
    Tsk, tsk, and from you too.
    Popeye's Hemi's Avatar
    Feb 2008
    Eastern Shore of Maryland
    Quote Originally Posted by HemiRedMagnum View Post
    I did not notice in your signature if you have a Predator, but if you do then I would data log and monitor the engines Intake Air Temp (IAT) and (ECT) engine coolant temp along with RPM and MPH. If I'm in city traffic or at a light my IAT is very high, but at highway speeds the temp is usually 8-10 degrees above ambeint. I use an early generation Carbon Air Hammer. I also have the lower front facia vents un-blocked and the brake fluid resevoir cover removed. My thinking is that it helps to allow air to flow through the engine compartment.
    Aug 2008
    my best numbers were with my molested stock srt airbox
