Results 1 to 13 of 13
    richierevs's Avatar
    richierevs is offline I Need DRs Really Bad....
    Mar 2008
    Stamford, CT
    Broke a piston in half!!! - Part 2
    I went to get the camshaft to send it to Chris (Hemi~C~) for the new engine build. While there I snapped these pics of my block and piston. Click on the links to view the pics.
    You can see the marks on the side of the cylinder in this pic.
    http://lxforums.com/board/album.php?...pictureid=5218
    Here's the big pieces of the piston that are left.
    http://lxforums.com/board/album.php?...pictureid=5219
    I guess the piston got really slammed around.
    Dec 2007
    So cal
    Holy crap! what caused that?
    FlyByU's Avatar
    FlyByU is offline MSHS
    May 2006
    Long Island, NY
    Ouch, thanks for sharing.
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    Quote Originally Posted by 5.7SublimeDaytona View Post
    Here's the original thread:
    Need Info on Short Blocks (a.k.a. Broke Piston Today)
    Just proves how soft/fragile the OEM pistons are. I'll be going back on Monday to examine the heads, especially for cylinder #7. I'll also be checking for metal fragments in the passenger side header--there were plenty of fragments on the oil pan.
    I'll post more pics next week.
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    make sure you clean out the intake manifold as well.....it's probably full of bits.
    BFNY PERFORMANCE
    RIP My Friend
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    ^^Agreed. What could go down (into the headers) could also go up (into the intake).
    sergeo'shemi's Avatar
    sergeo'shemi is offline True failure is the failure to try!
    Jan 2008
    Chicago IL
    so is this an excuse to go stroked?
    400ci stroker, Vortech blower, and enough said
    07 Magnum Srt8 incognito brute
    Sprayed Charger is offline I like spray
    Feb 2009
    Chicago
    for sure
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    Quote Originally Posted by sergeo'shemi View Post
    I was really tempted, but I don't have the cash to do right (bore and stroke). However, I will have Diamond forged pistons and K1 billet connecting rods and Chris (Hemi~C~) is setting the rings so I can add a S/C later.
    What matters now is whether I'll be able to use my existing camshaft and heads. The camshaft looked OK, but Chris is going to have it mic'd and scan'd. The heads are a different story. It all depends on whether there's damage to any of the valve seats. As Eric indicated in his OP, if the intake has debris (metal framents) then there's a good chance that other valve seats may have become compromised besides cylinder #7. After the heads are cleaned and the bent valves replaced, I'm going to have the heads pressure tested.
    Anyway, I'll keep everyone posted on progress.
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    Good News
    Yesterday I had the chance to examine the heads. Aside from some minor dents at the top of cylinder #7 the heads look good. There aren't any sharp areas that could become "hot spots". Later this week the cylinder valves will be replaced and at that time the valve seats will be examined. I'm also pleased that all the valve locks are prestine--no visible signs of wear.
    CRS MSL's Avatar
    CRS MSL is offline Do Not F*** With Us
    Mid Valley Oregon
    Jeez.... I should have contacted you instead of Stu for blown pistons, that cracked one is a winner for sure!
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    Quote Originally Posted by CRS MSL View Post
    Yea, I guess this is my 15 minutes of fame.
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    Well....Just learned from Chris (Hemi~C~) that my camshaft shows signs of excessive wear, so it's another piece for the scrap heap. I decided to order another HHP Stage II camshaft from Josh since it's a proven performer.
    At this rate, I shouldn't be disappointed if my heads fail the pressure test.
