Originally Posted by
richierevs
I'm assuming the the wire through the grommet is for an activator switch that will engage one or more relays (1 for each cutout motor with separate inline fuses?) The switch would be either DTDP (double throw, double pole) or DTSP (double throw, single pole) so you can enable both motors from a single switch and the power would be sourced from under the hood rather than from inside the cabin. Relays would be located under the hood. Therefore, the wire(s) through the grommet wouldn't be going directly to the cutout motors but to the relays. Does this sound similar to what you had in mind?
