You have a thermostat stuck open I bet, I had the same issue last year. Car never heats up past 165 degrees or so and after a certain period of engine run time it throws the code because you haven't hit expected operating temp ... you are in PA, I would not recommend the 170 degree T-stat ... you can get away with the 180 but your feet may not get as toasty as you'd like this winter ... there is nothing wrong with the stock 195 degree unit ... be warned, if you choose to get a 180 degree you will also need to get a gasket for it from a 3rd party store, not the dealer. My advice is, run the 195 in the winter and change to the 180 in the spring ...
just my 2 cents
