I had and still have the delayed change fro R to D and from D to R.
Took my car in the have it checked out, the dealer checked for fault codes and drove the car.
Bottom line is that these gearboxes for the 5.7 and 6.1's have a built in delay, presumably to protect it and extend life, it also prevents slamming into D from N and flooring it so it is effective in this sense, however still irritating.
I received some responses when I posted about this on the SRT8 forum and all had the smae issue and it is normal for a small delay.
The extended delay you seem to be having now should then be tune related.
Goodluck!
BlueBee266
K&N CAI, Jet 180Tstat, Predator,Magnaflow HF cats and cat back, Mopar strut brace, Billet catchcan, Eibach front and rear sway bars, Eibach ProStreet S Coil Overs, Pedders bump steer kit, Comp XFI273H-14 Cam, Comp Beehive valve springs, Arrington pushrods, SLP underdrive pulley.
