Results 1 to 15 of 20
    aliveguy5 is offline GTL
    Dallas
    6.1 plugs in 5.7
    First can this be done? Second should I go a stage cooler with my mods? Would there be any benefit or should I just stick with the stock plugs? My mods are listed below.
    Mods: Jba shorties, catless mids, FLowmaster 44's, stock resos, MHP Catch can,MTCM,No-esp mod,Performance Electronics, Electronic Shift Kit, and the Inertia Motorsports Spartan Camshaft.
    mexi's Avatar
    mexi is offline thats my sippy cup!
    Feb 2006
    N Misssisspi . Memphis TN
    i would stay with stock plugs with your setup.
    mopar 11
    Corsa Hotchkis ...so far.
    Bizzle's Avatar
    Bizzle is offline Stock Sucks!
    Dec 2007
    Riverside, CA
    Yes it can be done. The NGK 4306 are stock heat range for 6.1's and are one step colder heat range for 5.7's
    2007 Charger R/T 6.1GONE!!!
    UNDER CONSTRUCTION
    1362#Sublime's Avatar
    1362#Sublime is offline Chargers, Its all about the Chargers
    Columbus Ohio
    If your not paing a grip for them, I would go for it, you should be makeing close to the power level a stock SRT8 is makeing. SO if the cheap as factory, thought it was a step in the right directions, I would have to say yes... Your are running 93 oct right???
    Iron Mike
    Frank Racing Inc
    6.1 431 Stroker ( Fully Coated shortblock set up for Boost, 9.6 comp,), 5.7 Exstream heads w .030 Mill, 2300 Harrop RDP Blower, FRI Camshaft ATI Over Drive Pulley,Labonte Motorsports Meth Kit, Little Nitros Kit, Dynatech Headers/Cats with a SLP LM2 , Pro Torque 3400 Stall, SRT Rear end w/ 3.06 Gears and DSS Halfshafts
    490 HP and 455 TQ Before Motor and Blower Baby
    Best Run to Date...
    11.539 with a 1.599 60ft 4250 Race Weight at 117.58mph
    Thanks to Steve AKA "Frank Racing", And Sohfast94! BAD A$$ Tuner
    Dallas
    yeah I'm running 93. CMR Tuned.
    richierevs's Avatar
    richierevs is offline I Need DRs Really Bad....
    Mar 2008
    Stamford, CT
    The stock 6.1L plugs are $10-11 per plug. You can easily do better on price by going with a less expensive copper core plug with a platinum tip (like Champion and Autolite). These plugs will be $2.50-3.00 per plug. Using the 6.1L engine as a guide, look up the corresponding replacement that's either a Champion or an Autolite. Personally, I've used Autolite copper core racing plugs and they've been flawless.
    Mymopar's Avatar
    Mymopar is offline Punishing the competition
    New England - CT
    I went with the 6.1 plugs when I did heads and cam.
    392 Modern Muscle Stroker, 3.06 rear, 2800 stall, Fri Stage 3 heads, ported TB, SLP long tubes, SLP underdrive pulley, Silver Box, TZ Chally hood, custom BT, KW V2 Coilovers, Hotchkis sways and custom fabbed End Links
    1969 (oo===]|[===oo) 1973 (oo /=====\ oo)
    1998 (O|||||||O) 2006 (Oo.|==+==|.oO)
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    you want the 6.1 plug with your mods.
    BFNY PERFORMANCE
    RIP My Friend
    MOL SRT-8's Avatar
    MOL SRT-8 is online now SHOW & PERFORMANCE
    Dec 2006
    SAN DIEGO, CA
    x2
    WWW.SHOWANDPERFORMANCE.COM
    SoCalLX
    Congratuation Del Worsham
    2011 Top Fuel Champion
    typicalmarine's Avatar
    Jun 2007
    Maryland
    Just curious, why is this?
    Hemi31's Avatar
    Quote Originally Posted by typicalmarine View Post
    General rule of thumb is 1 step colder plug for every 100hp increase.....this is to help control detonation with the increase in cylinder pressure and heat of the new found power.....it's also nice going to the platinum(no more 30k plug changes).
    BFNY PERFORMANCE
    RIP My Friend
    mexi's Avatar
    Feb 2006
    hmmm... looks like i need to change plugs...lol
    mopar 11
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    ^^Ditto.
    Also, from what I've been able to find out, platinum will be on the cooler side of a heat range while iridium will be on the hotter side. A heat range is just that, a range.
    That said, a platinum plug is cooler than an iridium plug within the same heat range.
    Ella C SRT's Avatar
    Ella C SRT is offline LX Padiwan
    AZ
    I swapped out the platinum plugs in my SRT for the equivalent heat range coppers. Changing them isn't hard to do and they seem equal in performance so the price difference was the main factor when it came time to change them out the first time. The coppers are less than $2 per plug.
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    Quote Originally Posted by Ella C SRT View Post
    If you're ever at a point where you want a little more longevity (> 30K miles) out of the coppers, the Autolite copper core racing plugs with a platinum tip will do the trick with only a nominal increase in cost per plug.
