Bob in Ocala, Florida (a 73 year old guy who loves cars), 05' Magnum RT. Many mod's, all of Danko Products and a few from 402 Motoring.
Have owned my share of 12 & 13 second cars, am happy now with my stock RT.
thx for the clear up....
My buddy from a local dealer got me the 6.1 gaskets bolts and studs for 30 bucks. He just left the dealer so im good. Im not going to keep egr.
Someone mentioned something about drilling an extra hole?
I know a diff dipstick is needed
I believe the extra hole is optional, only drill it if you want to use the extra bolt hole?
Lay the exhaust gasket onto the manifold and check out the holes in the gasket.
A new 6.1 dipstick may not be necessary, you may be able to slightly bend the 5.7 dipstick tube - if so, then you need the small spacer to bolt it back in place.
Bob
6.1 manifold on left, 5.7 manifold on right:
Notch needed for EGR:
My notch is just started, needs to be bigger. See the dimple above it? That would be the extra bolt hole:
Here is the 5.7 exhaust gasket on top of the 6.1 exh manifold:
i JUST USED THIS WRITE UP, WELL DONE FELLOW LX'ers. Only thing i did different was i kept the egr with out the notch..no problems, but will be soon getting this turned off from the tune. I recommend anyone doing this mod, to remove motor mounts, this will make your job 10 time easier. also do the mid muffler delete...sounds GREAT feels stronger (no joke). I did run a P0401 code, but this is due to the high flow...only after i am doing above 90 MPH...stays off otherwise, but the tune will handle that..nothing major i am told. i just use the Intune and clear the code...
P.S 2 sets of hand is better than 1...make sure u have a buddy to help will make like that much easier...TRUST ME..............Oh and no bending dip stick...fit back in perfectly.
Update on my progress with my exhaust swap - I chickened out and sold all my exhaust parts......
I decided to keep my stock exhaust, the 6.1 exhaust install looked to be too much work for my son and me.
Our health is not that great and I didn't want to push our limits.
My stock RT is fast enough for me................
Bob
I did this swap to my 09 Grand Cherokee and made a big difference. Srt8 headers and complete exhaust with reso delete. Not a very hard swap to do and no lift required...... Great bang for the buck...... TBF
