Do any of you V6 guys have the deltaflow muffler? I've heard the sound clip but if you have one installed what do you think about it?![]()
If you take the resonator off, the drone is unbearable! After I did mine, i found some of the v8 guys that put on 12" glasspacks as resonators and they said it helped dramatically. Luckily at the time FM had a gurantee that if you didnt like them, they would allow you to swap paying only the cost of the install of what ever you replaced it with. So $150 to install FM40 and then $35 to take them off and install the dynomax. To figure out that I didnt couldnt live with the drone, it only cost me $35 over what it would have cost to install the dynomax to start with.
After damaging my dynomax and fixing with JB weld, I will be looking into the 50s, they have less drone. I installed the 50 on my Ram and it had the classic "Flowmaster" sound but was livable to drive. The ram didnt have any resonators to start with, so i think the sound would be about the same.
Can i use the stock res?
sure, i should have done that when I did the original install. Probably would still have it.
