I just had new Kook's long-tube headers installed on my SRT8 Charger yesterday with the aluminum gaskets provided by Kooks. High temp sealant was used on both sides per instructions and locking ARP header bolts ($70) were used as an extra precaution against leaks.
I drive it to my tuner (SVS in Sacramento) yesterday and he did a smoke check on the headers as he had problems tuning two other SRT8s with Kooks headers. In those cases he found the Kooks-provided gaskets were not sealing. He switched to OEM exhaust manifold gaskets and had no further problems.
The tuner found one of my headers were leaking like a sieve at the gasket.
I telephoned Josh at HHP and he told me he doesn't use the Kook's header gaskets either because they don't work and often blow out shortly after install. This will cause the car to run roughly.
He told me he also uses the OEM exhaust manifold gaskets because he had to eat replacement costs on several sets of Kooks gaskets.
My installer put on the headers while the heads were out of the car for significant time savings while doing a head/cam install. I am now going to have OEM gaskets swapped in for around $600 in labor (estimated) plus the gaskets (relatively cheap).
No one told me that this was an issue (I wish I had known) and Josh said Kook's had changed their gaskets (for the worse) in the last year. Please use the OEM gaskets and save yourself a bucket of money!!!!!!
I called Kook's and left an angry message which I don't they'll reply to. My opinion of their company had greatly diminished because of this. My installer also said their O2 sensors took an hour to make fit as well. In addition to this I was shorted a bolt for the midpipes and one of the headers was bent at the collector end from the factory (Kooks box was perfectly intact and not dented).
What pisses me off is that you think these guys would know enough about headers to either make a decent gasket or at least suggest using the OEM ones.
5.02 @ 145 on 275's 88mm sbf turbo
