    The Tran's Avatar
    The Tran is offline Oh yeah baby!
    Texas
    Where do the wires come out of the amp?
    Ok so I recieved my LC-2 and I want to hook it up as close to the dash as possible.
    I see where wires are connected to the amp in the front. Are these the wires coming out of the amp, going into the amp, or are the wires going in and coming out of the amp on the same connector?
    Thanks
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    crap I don't remember and my car is at the dealer...
    As I recall the front most connector is the speaker connector and the rear most is the input from the radio.
    check the wire colors gave you in PM, the connector that has those colors is the OUT to speaker connector..
    there should only be two connectors on the amp, one coming in from the radio and one going out to the speakers, the one with the more wires in it (green and grey wires) is the out to speaker wires you want to tap into...
    The Tran's Avatar
    Texas
    oh ok cool. both connectors are under the amp. you have to pull the matting down to see the plugs. the one with the least wires is the one closest to the frame.
    thanks again for all your help.
