what are my option for Bluetooth? factory style
I'd like to add the bluetooth fonction to my 06 magnum. So far from the reading i did i found i could go with the mirror unit that was installed on 06 LX or i can go with the MyGig radio and add the microphone. Which is the easiest way? I've read the threads in KB and i'm still not sure what is best for me. What is involve in each of these two options? I mean for parts and work. Of course i know that if i go the MyGig route i can have the GPS as a bonus.
06 Magnum R/T brillant black, JBA headers/mid-pipes, 3.06 SRT rear, C&L CAI, Trinity CAI 91 tune, BT pistol grip, Kicker audio upgrade, MSRT wheels
There must be someone around who added u connect on his car.
I've read up on it and found out that you need the mirror with the bluetooth and a replace a control box that's connected behind the glove box on the right hand side. The control box connects the bluetooth with your radio system to hear the person your talking to through the speakers.
If your car was factory-wired, then you need the telematics module that mounts behind the glove box, the rearview mirror w/ the controls and microphone in it, and the harness that runs from the bottom of the a-pillar up to the mirror. If the car was not factory-wired, then you also need the "jetpilot" harness (named after our very own member Jetpilot who pioneered the thing)... This harness goes from your a-pillar, to your radio where it plugs into both the radio and the car, and over to where the actual brain mounts - it adds all the wiring that is missing.
To check if you're factory-wired, pull off your a-pillar trim and count the wires in the connector at the base. Or, pull your glove box out and feel around for the plug to be taped up out of view somewhere. If your car is an '06, chances are good you were not factory-wired.
I checked and found it's not wired. Is the jetpilot harness still availlable? Or am i better to go with a MyGig setup? Then i'll need to find which MyGig works for my magnum.
Yes it's still available. Don't know if anyone stocks them North of the border, but I know Moparsupercenter.com still has them down here.
- You may not post replies
- You may not edit your posts
Forum Rules
