Results 1 to 10 of 10
    Biig O's Avatar
    Biig O is offline LX Padiwan
    Jul 2008
    Milwaukee, WI
    Want to swap all six speakers
    As you all always do please help me out I want to swap out those paper BA 6x9s & 3/12. in the rear and the doors. Are their any drop in replacements. I am not too interested in the kickers. I have a 05 magnum nav 6 speakers. I am sure a factory amp is in, i just want better sound. Thanks
    Procharger | Cam | 538rwhp | 489tq | Blue tops | 09 axles | Nitto 555R
    schexy1's Avatar
    schexy1 is offline LX Padiwan
    Albuquerque
    Try the 2Ohm Infinity Kappa series
    Biig O's Avatar
    Jul 2008
    Milwaukee, WI
    2Ohms
    So all six speakers should be 2 ohms? would this be a big load on the nav/amp?? Thanks
    mrjoecool's Avatar
    mrjoecool is offline way down south
    Oct 2008
    thibodaux la
    replace them with boston acoustic SL series speakers you will be well satisfied
    Biig O's Avatar
    Jul 2008
    Milwaukee, WI
    those are 4 ohms?
    will my factory setup push those?
    schexy1's Avatar
    Albuquerque
    Your factory speakers are 2 Ohms so there will be no issues with the Kappas. If you go with 4 Ohms you will loose a little max volume. The max volume loss shouldn't be an issue unless you think the system isn't loud enough already. Either way, most mid to high end aftermarket speakers should sound better than the factory setup.
    Djv3n0m's Avatar
    Djv3n0m is offline LX Padiwan
    im running all kappa series. amp on the 6x9s and the stock amp on the dash speakers. people think i have subs in the trunk from the quality
    current mods....... too many to list.
    Biig O's Avatar
    Jul 2008
    Milwaukee, WI
    kappa
    are you guys running 4 6x9's and what model is a direct fit, most sites cruthcfield ie, says no 6x9s in the back will fit
    Thanks
    Biig O's Avatar
    Jul 2008
    Milwaukee, WI
    kappa
    Kappa 693.7i 2 ohms
    i think I am going to pick up/order four of these today. I will run of factory,or install JL audio A4300 4 channel. Did you replace the 3 1/2 dash speakers?
    TxCowboy's Avatar
    TxCowboy is offline Ride my famous Murder Ride
    May 2006
    Spring, Texas
    I was just check out some kicker speakers this past weekend and liked them a lot. Just curious, but what didn't you like about them?
