I have wanted to upgrade the stock sub for a minute now and keep factory REC, but wanted to do it on the cheap. I have an old school Kicker XS50 amplifier and Fosgate 10" DVC sub. The sub fits fine in the stock enclosure . I just came up on two modules for the XS50, which is why I am finally doing this. One allows the use of two modules (have Subwoofer module aready), the other is a remote gain and treble control module.
I will be tapping into fuse 18 for the remote, ground and power are easy, but not sure how to connect the rca's or signal input wires into the system. I have a soundgate locpro which gives me RCA's, just want to know which wires to tap the rcas into. Do I even need this?
In the kicker instructions, it has everything still using the stock harnesses. I like the ease of that. The parts that confuse me are steps 16-18. Do I use the locpro to tap into pins 2 and 3 (the signal input) or just get an rca to bare wire connector? In step 18, are pins 4 and 5 the speaker wires? Do I tap these and then run them to the amps speaker connections in order to keep harness functionality or just run the speaker wire direct from amp to sub? Any input would be appreciated. Thanks
