Results 1 to 12 of 12
Thread: Vss Solved!!!!
    Smoove06CSRT's Avatar
    Smoove06CSRT is offline Kiss my Rims.. They gots BIG lips!
    Nov 2005
    Vss Solved!!!!
    Screw Periferal...... They are taking too long and give the most usless updates on the phone....it is the very predictable "2 More weeks till release"...
    Here ya go!! I will be ordering this on Friday and I cannot wait to install...
    Soundgate Canpulse2
    Happy Navigating...I will be trying to work up a GB with someone here before I order.
    http://www.me-mag.com/installerCentr...dy.cfm?nid=519
    2006 300cSRT8
    Fastest color...... Bright Silver Met.
    "OHH! A Strip Club.....I'll Get my sweat pants on!"
    nick_danger's Avatar
    nick_danger is offline 2 Fast, not that Furious
    Aug 2005
    Richfield, MN
    Hmm... so will this device let me use the nav system to its fullest when going over 10MPH? Or is it only for adding aftermarket nav?
    UnderTaker's Avatar
    UnderTaker is offline Bring out your dead!
    Oct 2004
    Norwalk, Connecticut.
    Ohhh Ohhh!!! Mememe!!!
    05 Blk Magnum RT RWD,Window Tint, Mopar CAI, B&G PCM Flash, Magnaflow Cats, Borla 125, "HEARSE" vanity plate, AR/311 20" wheels W/Goodyear F1 245/45/20, 4X R1 D&S Rotors, LED tails, AAC Halo's suck - replaced with 402 motoring lights (sweet), Custom LED turns, Wired V1 W/Remote Disp, Kenwood Excelon 715dvd w/ NAV, iPod, 2x Diamond Hex 6.5, Eclipse Titanium DVC 12" w/custom enclosure, JL 1000/1, 2x JL 300/2, 2X Optima Batt. w/ Isolator, Rear Shaved, R Sylvania Turns
    Mighty Noid's Avatar
    Mighty Noid is online now time to paint the car soon!!!
    Aug 2005
    SoCal
    This is just for the aftermarket nav units not for the factory (OEM) units.
    Thank you Bigal470
    linuxkidd's Avatar
    linuxkidd is offline LX Padiwan
    Jan 2005
    Chapel Hill, NC
    Keep in mind.. You'll need to track down some CAN-C Wires.. The PDF states it's not compatible with the Interior CAN Bus ( CAN-B in DCX Terms ). Not hard to do... Just something to consider.
    LK
    '06 SRT8 Brilliant Black Charger [ Pix ]
    "If you can read this, the light is still red."
    UnderTaker's Avatar
    Oct 2004
    Quote Originally Posted by linuxkidd
    LK
    laymen's terms?
    linuxkidd's Avatar
    Jan 2005
    Chapel Hill, NC
    Ok.. Sorry for all the Jargon. LX ( among other vehicles ) utilize a data bus system call Controller Area Network ( CAN for short ). All Chrysler vehicles use 3 different CAN buses inside the vehicle.
    CAN-B -> Interior Comfort systems ( Stereo, AMP, Climate control, etc.. )
    CAN-C -> Engine & Mission critical systems ( Engine, Transmission, ESP, Anti-Lock Breaks, Air bags, etc.. )
    CAN-C Diagnostic -> Connect from a central Gateway ( which is connected to both CAN-B and CAN-C ) to the OBD-II Vehicle Diagnostic Connector ( under the steering wheel ).
    The Stereo as stated above has connections to CAN-B. So, When you pull the Factory Head out, and go to put an aftermarket head in.. You will have direct access to CAN-B Wires.
    The device talked about in this thread is not compatible with CAN-B. So, you will need to track down and tap into a pair of wires in the vehicle which connect to CAN-C so that the VSS device will work correctly.
    Does that help?
    LK
    UnderTaker's Avatar
    Oct 2004
    Ok.. The device talked about in this thread is not compatible with CAN-B. So, you will need to track down and tap into a pair of wires in the vehicle which connect to CAN-C so that the VSS device will work correctly.
    Does that help?
    LK
    yea - thanks for laying it all out...
    dont suppose what wires will need to be tapped into & where they are....
    i hate not having full functionality of my NAV....
    Nov 2005
    the can wires for this unit are behind teh glove box.
    2006 300cSRT8
    Nov 2005
    My SoundGate CanPulse2 is here!! I will be installing it this weekend! and I will be pics and how to's on it as well....
    2006 300cSRT8
    linuxkidd's Avatar
    Jan 2005
    Chapel Hill, NC
    Congrats!!
    Hey hey... What was the tally on the order??
    LK
    Nov 2005
    I have a buddy who owns a stereo shop... he got me a good deal.. I cannot say how cheap... but it was under the MSRP of 199!
    2006 300cSRT8
