Results 1 to 6 of 6
    sleezerRT's Avatar
    sleezerRT is offline LX Newbie
    Oct 2009
    Acid Valley, MN
    Volume not working
    For some reason the volume on my Magnum's stereo stopped working. It is stuck on 0. I can't turn it up from the knob itself or using my wheel controls. This has happened before and I have been able to restore volume control by switching my modes from either AM/FM to tape or CD. Now it doesn't work at all. Anyone encounter this?
    JonW's Avatar
    JonW is offline LX Flasher
    Jun 2004
    Huntington Beach, CA
    Do a battery disconnect for about 5 minutes or pull the radio fuse. I've seen it a few times and a battery disco always fixes it.
    " Where Southern California Car Culture Meets Modern Mopar Muscle"
    josh05magnum's Avatar
    josh05magnum is offline Need. More. Mods.
    Plainfield, IL
    Do the numbers go up when you change the volume?
    Have you re-programmed the car with a Predator recently?
    2005 MAGNUM RT
    AIRHAMMER, Predator, 180 Tstat, Flowmaster 44's w/ Zoomers Cannon Tips, Blue LED Interior Lighting, 06 Radio with Aux Input
    sleezerRT's Avatar
    Oct 2009
    Acid Valley, MN
    The car is untouched and the numbers will not increase. they just stay on 0. It has done this about 5 times during the 3 years I have owned it. It is getting more regular in occurance.
    I just found out tonight that if I put in a tape I can get the volume back.
    JaxHemi's Avatar
    JaxHemi is offline LX Padiwan
    Jun 2005
    I had this issue when the car was new. Dealer thought I was nuts since of course it never did it while they had it. They finally agreed to replace it. They could never figure out or tell what was wrong. I know what you're going through. At the time all I could do was cycle from one audio source to another and then back to what I was listening to and the volume would return. Sorry I couldn't be of more help.
    sleezerRT's Avatar
    Oct 2009
    Acid Valley, MN
    Yeah if it continues I am going to have it replaced as well. It seems to be fine now after using the tape deck. I have started to look for an 06 deck so I can get the Aux input. The 06 deck still has a tape player right?
