Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    Todd 06R/T R&T is offline LX Padiwan
    Charleston, SC
    Upgrade Stock BA System
    I have the NAV / 6 spkr Boston Acoustic system. For a stock system with no sub, its really not bad, but I'd love to add the BA sub that is an available option.
    Has anyone done this? I haven't pulled the cover down from the rear dash yet, but I understand there is a plug there for the amp / sub to be connected too.
    Any insight / experience woudl be helpful.
    Todd
    2006 R/T R&T
    Mopar Performance Sway Bars, Mopar Strut Tower Brace, AFE Stage II, DiabloSport Predator 93 CAI Tune, 180 Tstat, Remote Start, ESP kill switch, added UConnect, added auto headlight swtich.
    more to come
    Todd RT's Avatar
    Todd RT is offline 05 Cool Vanilla Magnum RT
    Tampa Bay FL
    First of all... kinda funny how close our forum names are!! LOL!
    I have a Mag, but I kept the stock BA system, changed to the Kicker Amp, added a 200W Alpine Mono Sub amp with a 10" single sub in a AON enclosure.
    Sounds COMPLETEY DIFFERENT!!!! It's the best sounding almost stock system.
    I really can't tell ya' much about the Charger BA sub connection, except the Stock BA amps are wired for a sub... but I think the 300 is the only one that uses that wiring.. and the amp knows it's not in a 300.
    I'm 99% sure that the Kicker Sub ties into the rear speakers.
    You'd have better luck getting one of the Pac Audio Add an Amp adapters, and going aftermarket for the sub and amp.
    Good luck Todd!
    Todd RT
    05 "Shagwagon" R/T
    Go USF Bulls!
    Hemi Registry #000514
    Charleston, SC
    The name similarity is funny.
    I have a pair of older soundstream 10's and a kenwood mono amp (runs at 2 ohms). I dont want to take the trunk up with boxes at this point, as much as I did in the past. I really want to use something that will mount in the rear deck and run free air. I dont think the soundstreams will do that effectively.
    Todd
    2006 R/T R&T
    more to come
    Charleston, SC
    BUMP
    sorry, someone must know how to do this or if it is possible.
    Todd
    2006 R/T R&T
    more to come
    risky's Avatar
    risky is offline LX Guru
    nj
    I am upgrading my BA system
    I am getting the 6 kicker speakers and the kicker amp to switch out the BA stuff, I will add the sub if it not enough for me. Just got the speakers and amp from this forums should be here this week, so I will post the results..
    BigHemi06's Avatar
    BigHemi06 is offline Race It????.....NO NO NO It's A Show Car
    West Palm Beach, FL
    I have the BA speakers i ordered the upgraded kicker amp this last week for Moparstore.com, with plans to add a sub in the back of the charger later depending on how everything works out with this amp, should have it thursday!
    Mods: 6.1 motor with PPP Ported Heads and 224/228 598/578 113LSA, stock tq converter, stock SRT headers with gutted cats, JBA 3in exhaust, LMI hammer design intake. The only 6.1 motor running a 2.82 rear.....Soon to be 3.06 gears.....Installs done by Afterhours Mopar Performance
    Charleston, SC
    Quote Originally Posted by risky View Post
    Let me know I'm really curious to know 6 speakers to 6 speakers how much difference it makes.
    Actually for a stock system with no sub I think the BA isn't half bad. It's better than the Bose system I had in my last GM car.
    Todd
    2006 R/T R&T
    more to come
    robbyho's Avatar
    robbyho is offline the curiously strong robbyho
    Dec 2005
    Milford, CT
    Quote Originally Posted by Todd 06R/T R&T View Post
    It's not bad at all actually. Another option is to mount an 8" sub in the rear deck where the stock sub should be. Then add an amp and tap into the rear speakers for your signal. Easy Peasy.
    Rob
    risky's Avatar
    nj
    Upgrade
    I am going to switch to kicker speakers and amp then add the sub and rear amp. thanks vic
    LGK's Avatar
    LGK
    LGK is offline LX Newbie
    Jun 2007
    Burbank, CA
    I did something like this to my 06 R/T. I found a stock BA 8" sub and
    the stock 7 channel amp on CF's. The harness for the sub is already there
    so it was all plug n play. I also swapped the rear deck speakers to the
    kickers but didn't like them. They were cleaner but didn't have the same
    low end the paper BA's have so I swapped back in the BA's. This was more
    of a personal preference thing, some would like the Kickers better I'm sure.
    If I were to add a sub to the trunk I think I'd go back to the Kickers.
    They are for sale if anyone's interested.
    LGK's Avatar
    LGK
    Jun 2007
    Burbank, CA
    From what I've heard from guys who've done this is it's an upgrade you
    need to do in tandem with the sub. The new amp is designed to run with the
    trunk subs (i.e. crossover settings) and kickers speakers and if you don't
    have one/both your going to be very disappointed with the bottom end.
    With the trunk sub added I hear it sounds awesome.
    Quote Originally Posted by BigHemi06 View Post
    risky's Avatar
    nj
    Magnum??
    Is the wiring for the rear sub already there?? Rear amp is it part of the sub or can you add a rear amp on the speakers..
    LGK's Avatar
    LGK
    Jun 2007
    Burbank, CA
    Wiring is already there for the 8" rear deck mounted sub. This sub
    is powered by the amp under the dash. The BA 6 speaker system has a
    6 channel amp, the upgraded BA system has a 7 channel amp. The amps
    look virtually identical.
    So if you want to add the sub you need the sub and the 7 channel amp
    but the wiring is already there as long as you already had the BA system.
    Edit - I have a Charger not sure if this is the same on a Magnum.
    BigHemi06's Avatar
    West Palm Beach, FL
    Quote Originally Posted by LGK View Post
    I upgraded from the BA 6 channel to the upgraded kicker amp, so the charger is already prewired for the kicker sub in the trunk so all i would need to do is get the sub and it should be plug and play??
    risky's Avatar
    nj
    I will find out when..
    I start to take the magnum apart what is there I will post the results..vic
