    300 on 22s is offline LX Newbie
    Switched acc in the 300
    I hear there is a fuse you can move for the console power outlet to make it switched (so it only turns on with the ignition on) does anyone know what fuse it is and where u move it to casue i have the touring and all the cig clighters are constant my friend has the base and his is switched anyone know nehting help please
    MagnumFreak's Avatar
    MagnumFreak is offline Chasing Dreams
    Jun 2004
    Evans, GA
    Service manual shows fuse 9 feeds console power outlet. and fuse 18 feeds the lighter. Fuse 18 is found in the rear fuse panel located near the battery. Fuse 18 is the fuse in the picture that is offset FROM the other fuses. Sorry it is a bit blurry but you shoudl get the idea. Just move it to the other slot to change the outlet.
    Hope this helps.
    2005 Dodge Magnum R/T
    -Martin Luther King, Jr.
    thanks i actuakky changed it about 1 1/2 hours ago i looked at my friends and his on the base 300 is already there my wasnt then i saw it actually says ignition right next to the spot on bottom so i moved the fuse down then ran a wire FROM that to the acc radio and it goes on and off with ignition the radio even stays on until i open the door like the stock one thanks!!!!!!
