Results 1 to 15 of 16
Like Tree1Likes
Thread: Sunroof quits - pulling and reinstalling fuse resets
    JimTurner is offline 300C Owner
    Mar 2006
    Orange County, CA
    My sunroof acts like it is the victim of a software issue. "Rebooting" the circuit via a fuse pull will clear the issue and allow it to open and close normally.
    It's happened 3 times in the last 2 weeks. I have not been able to correlate this to anything in particular that I am doing.
    Any ideas?
    Cool Vanilla 2006 300C Build 09-05
    Hotchkis Swaybars / SRT8 Suspension
    Magnaflow CatBack (customized by MF)
    Spyder's Avatar
    Spyder is offline Friendly neighborhood Syndicate Spyder
    Sep 2009
    Moreno Valley, CA
    Its been a high of 60 degrees in the OC recently. Why have you been opening your sunroof??????? Its a bit chilly right now.
    2005 Cool Vanilla Magnum RT *Daily Driver*
    Airhammer/BilletTech Goodies/SRT Wheels/ FlashTech Halos/ Custom Sidemarker Spider/ BilletTech Magnum wing/
    *Still need to finish my CarPC (70% completed)*
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    Quote Originally Posted by JimTurner View Post
    Any ideas?
    has it ever been updated? there have been a few flash updates for it..
    Quote Originally Posted by Spyder R/T View Post
    sissy
    all windows down, sunroof open, heater on full, heated seats on high -10 outside..
    "Scars heal... glory fades, and all we're left with are the memories made, Pain hurts, but only for a minute, Yeah life is short so go on and live it; Cause the chicks dig it" - Chris Cagle
    Spyder's Avatar
    Sep 2009
    Moreno Valley, CA
    Quote Originally Posted by JetBlack300c View Post
    sissy
    Actually I do that too, I just don't open the sunroof. I love the fresh air in the car.
    Apr 2006
    yup.. I used to travel to NYC for my last company and always tried to get a convertible as the rental, then drive around NYC in Feb with a convertible top down, unless it was actually snowing..
    even them New Yorkers thought I was nuts...
    my first wife and I used to go up to WrightWood or Big Bear and Ski in a t-shirt and jeans... never got sick either..
    BDA1855's Avatar
    BDA1855 is offline Ultra Heavyweight "Fatman" Race Team
    Nov 2008
    Riverside, CA
    I agree... nothing is more fun than cranking the Heat... opening all the windows and sunroof and going for a drive...
    2006 INFERNO RED MSRT8 - SOLD-
    2005 FORD P71 Crown Vic
    DREAMING OF A NEW MOPAR
    prican_2000's Avatar
    prican_2000 is offline Hispanic causing Panic!!!!!!!!!!
    MD
    I have those gremlins in my electrical system also. fuse pulling seems to fix it for a lil while at least.
    "Death Smiles at Everyone -- Marines Smile Back"
    MOD LIST: C/F Hammer, Flowmaster Ex, FRI-Sidewinder Cam, Gibson Headers, Predator, B.T. Ported T.B., Lil Silver Box, Red Illum Rear Wing, Blue Angel Eyes, Yellow HID FOGs, 09 Intake, CTP Spacers, SRT Rails & Injectors, SRT Rear w/3.55 Gears and 2010 R/T Axles....What's Next?
    rlma84's Avatar
    rlma84 is online now LX Padiwan
    Nov 2010
    Cape Coral
    Same issue in my 06 charger Daytona and the fuse also fix the problem for some time if there is any fix please help!!! i don't use sun roof so much but I hate to pull over and fix it every Time I decide to use it
    Mar 2006
    Orange County, CA
    Sounds like a trip to a flasher is in order. ;-)
    Sevenernine's Avatar
    Sevenernine is offline I'm doper than Floyd Landis.
    Jan 2009
    Lawrence, Kansas
    Mine did this for the first time today. It did that thing where it backs up while closing like there is something in the track, I said **** it 'cause I was parked in my garage... And when I got back in, it wouldn't move at all. I turned the car off then back on and held the 'lift' button and it closed. But it was weird.
    Making sexy look easy since 1983.
    Stay Subtle
    Quote Originally Posted by CVP33 View Post
    Get a procharger. I only chirp 4th now. The other gears are just a blazing, screaming, tire shredding, smoke filled show of power. But definitely no chirping.
    Shelby's Avatar
    Shelby is offline LX Padiwan
    Jan 2006
    Just for those that do not know, the sunroof is fuse #44 in the rear power distribution. It is one of the square fuses with the clear top.
    scorp is offline LX Padiwan
    Apr 2011
    Is there a relay for the sunroof? Maybe a bad relay.
    rlma84's Avatar
    Nov 2010
    Cape Coral
    Anyone found a solution on this???
    rlma84's Avatar
    Nov 2010
    Cape Coral
    I found this and I do have a CHYP module for iPod so it makes sense
    CHYP issue
    I just wanted to chime in that I have the exact same issue: My Ipod CHYP makes my sunroof completely unresponsive until I pull out the 44 fuse for 5 seconds, and put it back in. The sunroof never loses power while in motion, it will simply not work when I start my car sometimes. This happens anywhere between a few days, or almost a month. The fuse never blows, and increasing the amperage on the fuse does nothing. I was going to try to put a capacitor in line with the fuse, but instead ran a wire underneath the carpet to under the drivers seat. If my sunroof ever stops working, I flick the switch off and on again. A little crude, but it works.
    I still don't know an actual resolution to the issue. It looks like the CHYP has a weird power output or fluctuation when the car is started, and there must be some logic or a lower amperage circuit breaker in the sunroof circuit which only resets when power is completely lost from the system. I can't say for certain, but it seems logical since the audio system receives power even when the vehicle is off, and disconnecting the battery or pulling the fuse fixes it every time. (I've read on other threads that the sunroof does have some logic which is to prevent damage to the sunroof components, and have also read that the sunroof does has a recalibrate feature which is done by pulling the fuse while the sunroof is in motion, but I haven't verified this myself)
    Corkit's Avatar
    Corkit is offline LX Padiwan
    Apr 2012
    Langley BC Canada
    Bump for an fix to this?
    I just installed my iConnect (or whatever) iPod hookup, and 2 days later my sunroof dies...
    If I take it to the dealer for the upgrade software, anyone know if I would have to pay for this?
    06 Magnum R/T
    ***** More to Come *****
