Results 1 to 15 of 19
    Hemi31's Avatar
    Plattsburgh,NY/Lorain Oh
    Stock single disc stereo question
    I have the stock single disc from my 06'R/T......I want to use it in my winter beater.....aside from getting my hands on a factory pigtail for the rear do I have to get a factory amp to use it or will the head unit power the speakers?
    RIP NHDave
    Zoban's Avatar
    Zoban is offline lil Red Wagon
    Feb 2008
    Oshawa Ontario
    Headunit should power the speakers fine as the headunits are the same between the SE,SXT,RT etc where the SE/SXT don't have the amp option and are a base 4 speaker system.. (matching headunits models of course a REF is an REF is an REF)
    Watch for power though as the 12v switched ISN'T 12v in the factory deck. Aftermarket headunits need to steal 12v from the lighter etc because of this.
    2006 Lil Red Wagon SXT
    Modlist : AFE Stage II, JBA Headers, Corsa Catback, 20" Vipers, Cross Drilled Rotors, Diablo Bob@SVS Tuned, Pioneer DEH-5000UB, 12" Enclosers, Halos, Low/Fog HIDs, Cuda Grille, TruFiber Chally Hood.
    at the Track
    My Garage
    Mentoria Computer Consulting
    Fargo59's Avatar
    Fargo59 is online now building for the better!
    Welland ON
    yeah, but he wants to put the stock head unit in another car.
    Hemi31's Avatar
    What does the factory deck use for power then?And what do I need to bring it down?
    Super T's Avatar
    Aurora, IL
    The radio needs the CAN signal to turn on, it doesn't just get 12V w/ the key on :-(
    Hemi31's Avatar
    So in other words outside of an LX it's a brick?
    Zoban's Avatar
    Feb 2008
    Oshawa Ontario
    Hmm..
    May have to try one of the two out in the garage on the bench and see what I can get or not get to work..
    Hemi31's Avatar
    Let me know.......the 8-track is getting pretty old.
    sound&security's Avatar
    sound&security is offline NOT MADE IN CHINA!
    Aug 2007
    FT LAUDERDALE
    Eric it uses a switched neg to turn on and off with key or door open.
    i'll try to find you a replacement harness from the head and build a relay for you.
    power is a straight 12v +
    Hemi31's Avatar
    Quote Originally Posted by sound&security View Post
    Ahhhh....ok......so 12v in and then a relayed ground with key on is all I need?Thats easy enough.
    Aug 2007
    FT LAUDERDALE
    metra part # 71-6502-1
    this will plug into the rear of your radio and then the switched red wire will be converted over to switched ground viva a relay.
    Hemi31's Avatar
    Thanks.....I'll order that pigtail......I'll PM you when it's time to wire it just to make sure.
    Super T's Avatar
    Aurora, IL
    You're the stereo guy... but are you SURE that you don't need a CAN module to get the unit to power on and function?? If not... hell, that's pretty sweet!!! I could swear though that people tried this years ago when the platform was new and that the radios were commanded on/off via the CAN twisted pair. For Eric's sake I hope I remember wrong!
    Aug 2007
    FT LAUDERDALE
    on the amped units yes big problem-but the non amped units have a built in amp just like any after market radio does. the power for battery is straight 12 volt and the switched ign is looking for a ground just like the GM's from 03 and up to current year.
    Hemi31's Avatar
    ok....wait....this came out of my R/T which had the BA sound.....that would be amped......no? Which means it wouldn't wwork right?
    Posted via LXFMobile
