I'm about to begin a stereo upgrade from Sound Group II (322 watt 6 disc 7 speakers) in my Charger with steering wheel controls. I'd like your input on whether or not there is a better approach. I want full range clarity above all else, power to play heavy metal properly, and sensitivity to handle classical.
I really like the head unit and steering wheel controls, so changing the head unit is out. My first preference would be grabbing the signal between the head and amp with a Peripheral CHYAA or Pac Audio C2A-CHY, but neither is in production now (May 2006). So, I have to use speaker level inputs to a line output converter with channel summing. I'm planning on using an Audio Control LC-6i.
Having researched the factory speaker outputs by reading this forum and 300C Forums, I put together this chart that I think is correct:
Here's the part I'd like input on: which channels go where on the LC-6i. Here's my plan:HTML Code:Location Watts Frequency Speaker Dash 24 100-16k 3.5 Doors 60 <120 6x9 Deck 60 100-18k 6x9 Sub 46 <50 8
It looks like there will be excess signal strength from 100 - 120 Hz due to the crossover overlap. How much of a problem will that be?HTML Code:Speaker wires LC-6i in Notes Dash N/A To Infinity Kappa 3.5" in dash Doors Channel 2 Summed to Main Channel Deck Main Channel To main amp F&R Sub N/A Disconnected
Here's where the signals will go next:
That means I'll lose fade adjustment at the head unit, but I can adjust it by altering the relative amp input levels. No biggie. The main amp is an Infinity 7541A 111 watts x 4 channels. The sub amp is an old Jensen 4 channel I have sitting around. It can be bridged to 150 watts x 2 channels, thus the DVC sub. The LC-6i and both amps will mount to the rear seat backs.HTML Code:LC-6i out Amp Input Main Y preamp cables to F&R main amp channels Channel 2 subwoofer amp
Now to the speakers:
Having owned Infinity Kappas with CMMD drivers, there simply is no other choice for me. Since the current generation Kappas have fiberglass cones, I bought two 6x9 CMMD pairs used via eBay. One pair is 3 way for the doors and the other pair is 2 way for the deck. The sub will probably be a 10" Infinity DVC that I plan to mount free air by cutting the deck. For me, thump is just not worth sacrificing much trunk space for and I expect the four 6x9s to do most of the sub's job anyway.HTML Code:Amp output Speaker Location Front 6x9 Doors Rear 6x9 Deck Sub 10" DVC Deck
The factory amp will still power the dash speakers, mostly to raise the sound stage. Since the door speakers will be full range, I won't need much output from the dash speakers to do that. I swapped the dash speakers for Infinity Kappa 3.5s a few months ago.
Is that a sensible plan? Where did I go wrong?
