Results 1 to 11 of 11
    snailtek is offline LX Padiwan
    Oct 2005
    Los Angeles
    Sirius Sat Tuner Antenna
    I will be getting a sat tuner (oem) and i need an antenna.. dyou guys know where to get it?
    let me know
    thanks
    05 Silver Magnum SE <= that's all i can afford =>
    Stock! Nothing Exciting! But.. got u-connect, homelink, NAV & VES, 18" R/T wheels.
    pukkaSRT8's Avatar
    pukkaSRT8 is offline puk·ka [adj.] authentic, 1st class
    NW Chicago Burbs
    you'd have to buy the oem one from a dealer.
    If you dont want to have to cut a hole in your roof, you can pick up a TERK SIR-MINI (make sure you get the one with the yellow Fakra connector)
    I picked one up recently from www.antonline.com for around $27 shipped IIRC
    Oct 2005
    Los Angeles
    just to confirm..
    is this the one?
    http://www.antonline.com/p_Terk--SIR...na-_246550.htm
    pukkaSRT8's Avatar
    NW Chicago Burbs
    yep, thats the one. It will have the single input yellow fakra connector.
    Now, if you bought the receiver used and its an early one (i think pre 06), you will need to get a Terk SIR-SP splitter as that need a dual input antenna (I want to say blue and white plugs). The later ones used the single input yellow plug.
    Do you have the wiring harness too?
    Big Daddy J 300's Avatar
    Big Daddy J 300 is offline RIP Flatnok, New Look Coming Soon!
    Anaheim
    yes he will have the wiring harness too, it was a bitch to get it all off had to pull the headliner off the rear and follow the damn wire all the way to the front lol
    Nok 300C
    Mods List: '08 MSRT Front Conversion, House of Kolor Tangelo Pearl Paint, 24" 2Crave No 12 Chrome Wheels, Fully Shaved (doors, washers, trunk, and fuel door) Gibson exhaust, Cutouts, Billet Tech, Laying Rocker with Universal Air, Polished Hood Shocks, R1 engraved rotors with Serious Metal conversion kit, SS brake lines, Ultimate Pedals, CF Paddle Shifters, 6.1 manifold conversion, polished engine bay, SRT John catch can Hard Lines, Braided hoses, glassback roof
    300MAG's Avatar
    300MAG is offline Going No Place Slow
    May 2005
    Woodstock, GA formally from L.I.
    PM NautcaSprt6, he had one for sale
    Oct 2005
    Los Angeles
    here is the picture of the tuner.. so what antenna do i need?
    pukkaSRT8's Avatar
    NW Chicago Burbs
    you either need an older (larger) oem roof antenna for that connection, or if you want a smaller antenna to mount on or under the dash youll need to get the TERK SIR-MINI with the single yellow fakra connector, then a TERK SIR-SP splitter to split the single input of the antenna to the dual inputs of the receiver.
    Oct 2005
    Los Angeles
    TERK SIR-MINI, TERK SIR-SP is coming.. now, i have a VES.
    what i really need is a connection wiring diagram.. or pdf for installing oem sirius tuner.. or any other info on installing this thing..
    thanks
    pukkaSRT8's Avatar
    NW Chicago Burbs
    pm me your email addy, i have the installation instructions in pdf format
    Oct 2005
    Los Angeles
    i really appreciate it.. thanks
