Originally Posted by
injunwiz
I bought a complete factory Sirius setup from a forum member for my 05 Maggie w/NAV and it arrived in Saturday's mail. I laid out the harness and removed all the items from the trunk to start with. I have NOT removed the NAV unit and ran the wiring as when I looked at the instructions for Magnum installation it only has one plug on the end that goes up to the NAV unit. It's a white plug with 7 wires total and the plug has a total of 16 pin holes. It measures about 13 1/2' ft long. The instructions show three loose wires that get plugged into the factory 10-way radio connector and a 22-way radio connector as well. I was told this unit came out of a 300 and was the same for Magnum. There is a p/n on the harness: p/n 05087104AE and the receiver p/n is 05064075AD. I called the dealer and they said the witing harness p/n I need is 5159035AA. Anyone have a take-off laying around they want to part with? Or a suggestion on how to make the one I have work? Thanks alot for the help! Jon
Got the same kit as you have and i got VES.
here is the picture of mine..
are u in Los Angeles?
05 Silver Magnum SE <= that's all i can afford =>
Stock! Nothing Exciting! But.. got u-connect, homelink, NAV & VES, 18" R/T wheels.
