Results 1 to 13 of 13
    IES99's Avatar
    IES99 is offline IES99
    Charleston, South Carolina
    Question Sirius: blocked reception
    I like my Sirius, but when I go under any overhanging trees (we have a lot of live oaks hanging over the streets here in the South), the signal cuts out. I thought little of that until my neighbor bought a new Lincoln MKZ (nice for what it is) and the Sirius in the Lincoln never cut out going under the same trees when we were on a little drive to look at the new car.
    Does anybody know what could be different?
    It isn't easy being GREEN
    Super T's Avatar
    Aurora, IL
    Is yours the factory installation? Mine only drops out when there are multiple stories of structure above me, or momentarily on steel bridges. It's been that way for... 6-7 years since I first installed it in my other car. Weird...
    MGM's Avatar
    MGM
    MGM is offline MGM
    Sep 2007
    Parrott, Georgia in Southwest Georgia
    Quote Originally Posted by IES99 View Post
    I live in Southwest Georgia and have very little trouble with losing signal. I have the factory radio. Of course I live in the country may be the difference.
    MGM
    Parrott, Georgia Half way between Albany and Columbus, Georgia
    2006 Daytona #337
    http://mgmonkus.googlepages.com/home
    IES99's Avatar
    Question Factory
    Yes, mine is factory. Bridges do that to me, too as do the overhanging oaks in the area where I live. It comes back on, but on and off, on and off. It makes it annoying to use around here. I was just taken by the MKZ's Sirius not doing that.
    boggart's Avatar
    boggart is offline LX Guru
    Pittsburg, KS
    Mine cuts off if I pull in my garage. I was under the impression it was line of site required.
    IES99's Avatar
    Question right
    Quote Originally Posted by boggart View Post
    Mine too. But why does the Lincoln do better than the 300?
    boggart's Avatar
    Pittsburg, KS
    That's a great question. I don't have the answer to that.
    IES99's Avatar
    Talking sirius
    I doubt Sirius knows (or will answer) either, but I will ask them.
    GoofyTimL's Avatar
    GoofyTimL is offline 300C H.E. and MSRT8 in WV... IS Heaven!
    Oct 2005
    Near Parkersburg, WV
    The first year we had ours (2006) it would continue well into a mountain tunnel, then finally cut out. After emerging from the tunnel it would take a little time before it cut in again... like there was a buffer somewhere that stored maybe 20 sec. of data.
    However, after the annual update/renewal it will not cut out almost instantly under and overpass, or thick foliage (trees). Have never understood why it's different now than it was.
    Still in love with my first wife, and first car ('68 Charger)... Still have the wife!
    Member #4079.
    poptones is offline aging punk
    Mar 2009
    M-i-s-s-i-s-s-i-p-p-i
    Mine cuts out often enough to be noticeable, not uisually enough to be annoying. It does it more in the summer when there's leaves on the trees, and does it under overhanging structures.
    Signal strength is going to have a lot to do with it, and the Magnum's antenna seems pretty bad to me. I think there's a replacement made for the oem but I don't care enough to replace it.
    Bill_in_Wilsonville's Avatar
    Bill_in_Wilsonville is offline <= That's my dog, Emma
    Wilsonville, Oregon
    *subscribed*
    I have the same problem. Lots of trees and constantly cutting out. Anything that can be done to improve reception would be great. Well, anything but getting a different car
    Previously known as 'alpha' and 'b.71'
    IES99's Avatar
    LX antenna
    Quote Originally Posted by alpha View Post
    *subscribed*
    I have to think the difference I noted between the 300 and the MKZ must be the antenna. The difference was striking to me.
    Still I like the C much better than the Lincoln (which is a gussied up Fusion).
    IES99's Avatar
    I may (and am not sure) but think I may have learned something about this. When we drove in the Lincoln, she had the Sirius on a jazz station and there was no cutting out. I tried that in the 300 last evening and under the trees: no loss of signal. When I switched back to Sirius 2 (Blend) the cutting out under the trees came back. I will keep trying this. I don't know how the Sirius satellite signals may differ, but perhaps better wavelengths are stronger and can penetrate more?
