Results 1 to 9 of 9
    typicalmarine's Avatar
    Jun 2007
    Maryland
    Should these prices concern me?
    Ive been shopping around for my next project and found the following.
    1. Are these prices too good to be true?
    2. I'm just adding the amp and sub, can anyone tell me if they see any issues with putting these two together?
    JL Audio 10W3v3-4 10" 300W 4-Ohm Subwoofer
    List Price: $259.95
    Our Price: $199.00
    Sale Price: $159.00
    You Save $100.95!
    Alpine MRP-M500 500W Mono Power Amplifier
    List Price: $230.00
    Our Price: $169.00
    Sale Price: $149.00
    You Save $81.00!
    http://www.mobilesoundworks.com/ShoppingCart.asp
    Thanks,
    Val
    diboblo's Avatar
    diboblo is online now LXHarness:Custom light mods & Harnesses
    Dec 2007
    Riverside, California.
    So long as you are comfortable purchasing from this online vendor, you should not be concerned about the prices. Most often, these are last year's models (nothing wrong with that) and that's why there is a price break.
    Your pairing of these two items shouldn't be a problem, as long as you run the amp at 4 ohms, to match the speaker. The amp puts out 300 Watts RMS at 4 ohms, and the speaker is rated at 300 Watts RMS at 4 ohms. It appears to be a single voice coil speaker, so it's plug and play (not many variables to wiring these together).
    Aside from my editorializing about audio components, you should be able to make this pair of products work well together
    Best of luck!
    Hope this helps...
    Bob
    Now tuned to Raise Hell!
    boggart's Avatar
    Pittsburg, KS
    While that amp and sub combo will work, you're not going to be using all of your sub. I'd suggest a bigger amp. One that you don't have to turn the gain up 100% to match your sub. That will make your amp get hot quicker.
    Jun 2007
    Maryland
    Ahh, I see what you're saying about the amp. So if I switched the sub from 4ohms to a 2ohms sub (they sell the same sub in 4 and 2 ohms) using the same amp putting out - RMS @ 2ohms is 500w, I'll be set?
    Thanks for your input! I hate trying to work this aduio stuff out because it fries my brain!
    Jun 2007
    Maryland
    Oh and I bought the following so I could use my I-Pod http://cgi.ebay.com/2005-2006-2007-D...2em118Q2el1247
    It has RCA jacks (not used) I'm assuming I can plug the amp into this, correct?
    boggart's Avatar
    Pittsburg, KS
    I don't think so. This is an input to get your ipod playing. It doesn't have outputs.
    Jun 2007
    Maryland
    Thank you very much for keeping me on a straight line!
    Oh, how about this one
    http://cgi.ebay.com/ebaymotors/2005-...mZ150269719099
    See this is what gets confusing, this "add and amp" is good for a 2 channel or 4 channel amp. The amp im planning to purchase is a mono/1 channel. Does this even matter?
    boggart's Avatar
    Pittsburg, KS
    You're on the right track with that one, but their application guide is lacking.
    Are you using a stock head unit or aftermarket?
    Jun 2007
    Maryland
    Stock Navigation/REC and I'll be keeping my factory amp.
