Results 1 to 15 of 21
    Grimlock's Avatar
    Grimlock is offline Dinobot
    Jun 2008
    Palo Alto, CA
    REC Navigation Help!
    OK I just installed the REC I got from a member in Texas. Everything is working perfectly except it thinks I am still in Texas rather than California!
    I drove around for 30 minutes and it moves around the map, at times it shows that it is seeing 3 satillites at time....but it still thinks I am outside Houston.
    What do I need to do to make it believe I am in California?
    Pleae Help!!!!!
    Grimlock
    2003 Corvette Z06
    2007 Charger SRT8 Gone, but not forgotten
    1969 Roadrunner in Red Gone, but not forgotten! <beep, beep>
    Super T's Avatar
    Aurora, IL
    Does it just have you out driving around in the middle of nowhere or what? I'd disconnect your battery for a while and let the unit reset again.
    Grimlock's Avatar
    Jun 2008
    Palo Alto, CA
    Yep I am driving around in fields according to the map.
    When I change direction it turns on the map as I do....just I am in Houston according to the map. Very odd.
    Grimlock's Avatar
    Jun 2008
    Palo Alto, CA
    Battery disconnected for 30 minutes and no change. I'm still in Texas.... :(
    Super T's Avatar
    Aurora, IL
    Quote Originally Posted by Grimlock View Post
    Well get some bbq while you're down there, it's good stuff!!
    Sorry man, that's all I got.
    adamwahhab's Avatar
    adamwahhab is offline PPPPSSSSSHHHHHH
    Feb 2008
    FRISCO
    try setting a destination in cali and see it if switches over
    viper3ez's Avatar
    viper3ez is online now Hello, my name is Nuvie.
    Jul 2007
    Bronx, NY
    Quote Originally Posted by adamwahhab View Post
    in my mygig experince, it switches over when its ready, not when you want.
    i'll drive with it some more(dont have to set destination) it'll adjust itself
    Quote Originally Posted by gr8crash View Post
    Its like paying $6K for your girlfriend to get a great boob job, then meeting a girl that has better boobs that are natural, are you gonna complain cuz you paid $6k for boobs for an Ex that aren't as good as the one in your hand? I think not.
    Grimlock's Avatar
    Jun 2008
    Palo Alto, CA
    Well I drove over two cities and back...and I'm still waiting.
    xlaboy's Avatar
    xlaboy is offline XLABOY
    Las Vegas
    Are you talking about a factory unit? Go to the screen were one of the words is HOME. Put in your home address, that is what is it for. Try that and see if it stays in your city when you are there.
    Grimlock's Avatar
    Jun 2008
    Palo Alto, CA
    Yep I've done that. Now it will guide me to my home....from Houston where it currently thinks I am....
    Super T's Avatar
    Aurora, IL
    Unplug the antenna (car off) and fire 'er back up. Hopefully it will go apes*** and realize it has absolutely no clue where you are. Then shut 'er off and reconnect the antenna, try again. Maybe that'll be the slap upside the head that it needs to reevaluate your 20.
    diboblo's Avatar
    diboblo is offline Just a guy with a car...
    Dec 2007
    Riverside, California.
    This happened to me, too.
    Go to the Nav Menu and find the Address Book. There is probably an address stored in there with a Texas address. For some reason, when this is the case, your Nav will default to the State in the stored address.
    Simply delete any addresses in the address book and cycle the key in your vehicle.
    The Nav should come back online showing you in California
    Let us know if this helps.
    Bob
    Now tuned to Raise Hell!
    Interior Lighting Color Change Mods!
    Grimlock's Avatar
    Jun 2008
    Palo Alto, CA
    Quote Originally Posted by diboblo View Post
    Bob
    I thought this might fix it too and it was one of the first things I changed. It now has my home address entered. So when I turn it on (at my home) and tell it to map my route home, it still thinks I am leaving from Houston!
    People are saying it will figure it out eventually. I will give it a few days and see.
    diboblo's Avatar
    Dec 2007
    Just so we're on the same page...
    I'm not talking about resetting the "home" address...
    Goto:
    Nav/
    Destination Entry/
    Address Book/
    From here, delete any stored addresses, or any stored folders with content. Once you've done this, cycle the key and your Nav should recognize...
    On a side note... I still have the HOME address of the previous owner stored in my Nav (which is in Nevada) and I have no trouble with my system acknowledging that I'm in SoCal
    Hope this helps,
    Bob
    Grimlock's Avatar
    Jun 2008
    Palo Alto, CA
    So if I am only hitting 1 to 3 satellites as I drive around (and many times none), could the antenna placement be the issues? If so, where should a mount it?'
    Right now it is mounted right behind the frame that holds the REC nav unit in. I have it velcroed in to a spot on the top right side behine the frame. If I should mount it elsewhere, let me know where! I can't more it around too much as the cord to comes with is darn short!
