I am getting the "please insert dvd" message on my Nav unit. The disc goes in and will eject when the eject button is pressed, but there does not seem to be any attempt to read the disc.
Any ideas?
Is this the same disc that came with the unit or a NEW one ??
Papa's Got a Brand New RIDE !!!
UAS Bags with Accuair E-level ~ Eibach Sways ~ Ported TB ~ BT Catch Can ~ R1 Drilled & Slotted Rotors ~ 8k HID High's/Low's & Fogs ~ Mopar CAI &Catback w/6.1 Blastin Bobs Kit ~ NoESP ~ 180 TStat ~ Blue Interior LED's ~ 12" Subs in Fiberglass Pocket Enclosures ~ Karlito Kreations Ashtray Plate- ~ 22" Staggered KMC Nova's ~ Shortie Wires ~ Tinted Tails ~ 6 Speed Challenger Motor Mounts
Now did it stop working while the disc was in the REC or did you eject the disc and then put it back in and it stopped working??
Just trying to do a process of elimination.![]()
mine is doing the same thing. just started last night. I took out the burned one and put in the old disc from 2006 and I still got a disc read error. WTF? Did the burned DVD damage the NAV unit? I was told that this can happen with burned discs and that it is not possible to go back to the old dvd. is this true? What has to happen to get my NAV back?
mods: AFE Stage 2, HHP TCM, Paddle Shifters, Lock Pick, Ipod Cable, blinker mod, Billet Tech. Catch Can, Air ram, Predator, EBC Yellow Stuff in front & auto zone in back, Hardwire radar with mirror mount, i995, Corsa Catback, 180 tstat, SVS Tune, Hidgate 6000k lows and fogs, Lighted cup holders, Pistol grip Shifter, blinker mod, custom k-9 insert
IF YOU FIND THIS FORUM HELPFUL BECOME A PAID SUPPORTER!AND IF YOU FIND IT NOT HELPFUL PLEASE DONATE SO I CAN CONTINUE TO BENEFIT FROM THIS FORUM!
Duce does the burnt disc not work as well ??
A few weeks ago when I put the (working) burnt DVD in, everyonce in awhile I would get a disc read error. I would turn the REC off for a few seconds then back on and everything was fine. Only happened about 4-5 times awhile ago.
Duce your problem may be that your original DVD is an older version then the new DVD. My original disc was AC and new burnt disc is AF. I haven't tried the original because I've had no need to.![]()
tons of threads on this..
try cleaning the dvd player, use a can of compressed air and blow some short quick bursts into the unit.
if it is a burned disc, try another copy.
else the unit is going out.. it is a common problem with the REC's, especially in hot humid weather, these units don't like heat..
"Scars heal... glory fades, and all we're left with are the memories made, Pain hurts, but only for a minute, Yeah life is short so go on and live it; Cause the chicks dig it" - Chris Cagle
I am kicking myself, no it was not anything obvious. I have the full MaxCare extended warranty so the dealer replaced the entire radio for me today. Doh! Should have thought of that before.
