Results 1 to 7 of 7
    jdl01gt's Avatar
    jdl01gt is offline LX Newbie
    Missouri
    question about amp bypassing
    I recently installed a kenwood dnx 7120 in my mag R/T and bought the metra CHTO-01 harness to intergrate the boston acoustic system. I have since added a new 4 channel amp to power my new mtx speakers and just used the output from the back of the headunit back to my amp, but am still using the CHTO-01 wired up to factory amp but have the speaker output unplugged from the factory amp. my question is does the factory amp still draw power even though the speaker output is unplugged from it? If so what harness would i need to buy to make it where the factory amp is not used. If not is it really hurting me to have it hooked up this way. Thanks in advance.
    2007 Magnum R/T- K&N FIPK, Triple Dipped Chrome Factory Rims, DNX7120 Double din touchscreen, MTX 1501d amp, and (2)MTX 9500 Subwoofers
    prican_2000's Avatar
    prican_2000 is offline Hispanic causing Panic!!!!!!!!!!
    MD
    Ummmm, I don't understand what your trying to do????
    If your running your speakers off the 4 channel amp then why are you worried about the B/A Amp??
    You can PM me if you want.
    "Death Smiles at Everyone -- Marines Smile Back"
    MOD LIST: C/F Hammer, Flowmaster Ex, FRI-Sidewinder Cam, Gibson Headers, Predator, B.T. Ported T.B., Lil Silver Box, Red Illum Rear Wing, Blue Angel Eyes, Yellow HID FOGs, 09 Intake, CTP Spacers, SRT Rails & Injectors, SRT Rear w/3.55 Gears and 2010 R/T Axles....What's Next?
    jdl01gt's Avatar
    Missouri
    i am not worried about the BA amp just wanted to make sure that unpugging the speaker output on the ba amp (Because the CHTO-01 is to be used to use the ba amp with aftermarket head unit) i am not powering it still
    MD
    SOOOOOOOOoooooooooooooo
    You just want to make sure that you are not sending juice to the BA Amp???
    89grand's Avatar
    89grand is offline LX Guru
    Phoenix, AZ
    Quote Originally Posted by jdl01gt View Post
    Well the factory amp is probably still receiving power, but it shouldn't really matter since it's not doing anything but idling.
    2000 Jeep Wrangler
    1966 Dodge Monaco 500
    jdl01gt's Avatar
    Missouri
    yes that is what i want to know so it is not really hurting anthing
    yitbos_magnum is offline SoCal Speed Junkie
    Oct 2008
    San Diego, CA
    From what i know about amplifiers in general, it will still dissipate DC power unless you unplug it from the battery. I am assuming it is a class AB amplifier so this will not be a whole lot of power, but it is still there at all times whether or not speakers are hooked up to it.
    If you're worried about it I would locate the amp and remove the 12V line from it.
