nope can't hurt anything... IF there is no power in the wire.. check it on a volt meter with the radio powered up before attempting to ground it, then test ground it (just touch to metal quicky) to be sure it doesn't short....
in my impala I put mine on a switch. ground the switch, wire from head unit to the switch, this way I could lock it out at will...
do a google search to see if there is any data on your head unit, I know some of them work differently than just grounding a wire...
