Results 1 to 5 of 5
    djh035's Avatar
    djh035 is offline LX Newbie
    PA
    Which Pac Audio do I need?
    I'm a new member(like the site) and need some help. What Pac Audio do I need to add a 4 channel amp to my factory radio. I have the 6-disc mp3 radio and don't want to change it,cut or slice wires to add an amp. Also is this a plug-in play type adapter. Where i find & what's the cost? thanx Peace.
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    Pac-Audio just released the C2A-CHY (I beta tested it for them for 6 months)
    the C2A-CHY, will add 4 RCA outputs to the OEM radio (front/rear left/right) from there you connect to your amps and from the amps to your speakers.
    if you want to add a sub then you also need the Pac-Audio LC-1 this is an RCA in/ RCA out Line converter, you add it to the C2A-CHY Rear channel RCA's and it splits them into 2 more (rear mid left and right and Rear LOW left and right) then you have 6 channels with RCA plugs (Front, Rear, Sub Left and Right)
    I have a C2A-CHY left over from a group buy I did here for Pac-Audio a few weeks ago.. PM me for detail..
    since the C2A-CHY was just released it is on a tremendous back order from most dealers and distributors, the "official" release was around 9/26 as I recall which was a "soft" release, only a few thousand where sent out. The massive major release was supposed to be yesterday if I remember correctly.
    djh035's Avatar
    PA
    pm you for more details sorry so late!!!
    mlgreen's Avatar
    mlgreen is offline LX Padiwan
    Milwaukee, WI
    Quote Originally Posted by Mr. iNCREDIBLE View Post
    Sorry to resurrect an old thread, but what PAc audio adapter would I need to hook up only an aftermarket sub/amp to my nav unit? Thanks!
    Todd RT's Avatar
    Todd RT is offline 05 Cool Vanilla Magnum RT
    Tampa Bay FL
    Same one... that's what I did... sounds freakin' awesome.
    05 "Shagwagon" R/T
    Go USF Bulls!
    Hemi Registry #000514
