Results 1 to 5 of 5
    dwhip's Avatar
    dwhip is online now DMV SLEEPER
    Jan 2008
    VA, but born in that 202 SW
    Overhead dvd player question?
    I have a sunroof/moonroof in my charger, and i want to get a overhead dvd player for my son so he can watch dvds while he sits in the back. My question is, first is their enough space after the sunroof to fit one? Second will the dvd player interfere with the sunroof operations, vice versa? Third, does anybody else on here have a overhead dvd player and a sunroof?
    When U see me in my town Everything is BLACK & RED!!!!
    donatello79's Avatar
    donatello79 is offline ellis-mate fan
    Jan 2007
    Ephrata Washington
    I installed car audio from 1992 to 2006 and yes it can be done. It is usually more appealing to do headrest monitors, cause you can replace the headrest much easier than a headliner with holes in it from mounting and wiring. And in some instances you can purchase the whole headrests with monitors and dont have to touch the factory ones. If the installer has half a clue, the overhead can be installed without an issue, other than the maybe the sunshade that slides blow the sunroof might have to be removed so it doesnt get damaged
    the727kid is offline LX Padiwan
    It can not be done properly.... it can be done but over time the headliner will begin to sag. Like mentioned, it would be best to go with headrest TVs.
    Mighty Noid's Avatar
    Mighty Noid is offline time to paint the car soon!!!
    Aug 2005
    SoCal
    Well my flipdown doesn't have a DVD built in but I do have a sunroof on my Charger... It has been installed for 3 years now and no sagging at all...
    BTW it is a 15.3" flipdown...
    Thank you Bigal470
    Gonin60's Avatar
    Gonin60 is offline LX Newbie
    Jun 2008
    Minnesota
    I installed an Alpine 10" with a dvd player in it, behind the sunroof there is a metal bracket that holds the sunroof rails in place and behind that there is a plastic bracket that holds the motor. I cut a piece of metal that I believe was 11.5x16x.375 and used a tap to cut threads for mounting it to the brackets and mounting the monitor to it with screws. It is mounted just behind the sunroof and the only way it would sag is if the roof itself sagged, and there is plenty of room to use the sunroof and slder with no problems.
