Ok, next question. Stock amp?
When you bypass the stock amp, does it still turn on and draw power?
I'm installing a new HU with a 4 channel amp and a 3200 watt mono amp.
I don't want any unnecessary current draw.
It shouldn't as long as you unplug everything out of the factory amp there won't be any power going to that amp.
Ok, thanks. I guess i'll find out when I get there.
Edit: Dug a little deeper and found somewhat of an answer SOURCE
- You may not post replies
- You may not edit your posts
Forum Rules
