Results 1 to 8 of 8
    Dirty Mo Posse is offline LX Padiwan
    Jun 2009
    Whitby/Oshawa, Ontario Canada
    Newbie MyGig Question???
    Hey Gang,
    I just purchased a 08 SXT Magnum and would really like to swap out the factory radio with a MyGig unit.
    According to what I read I need a Low Bus unit for my 08?? Is this correct??
    Also is it as simple as plug & play???
    Thanks!
    :D
    Jon (Posse)
    xj31 is offline LX Newbie
    Jan 2008
    It should plug right in.You need the low speed or CAN B version.If you get the RER with navigation,you will need an antenna.If You have Uconnect,You will need a harness to get it to work with the RER,because the HFM is in the RER,it is seperate with any other radio including the REN that doesn't have nav
    Jun 2009
    Appreciate it thanks!!!
    I have a line on a rec unit from a 2007 300 srt8. (Part# 05064184AE).
    Do you think it will work in my 08 Magnum??
    Thanks!
    :D
    Posse
    Jan 2008
    I thought you wanted a MyGig.The REC has different connectors,so it wouldnt plug in.I'm sure you can make it work
    Jun 2009
    Quote Originally Posted by xj31 View Post
    OK, now I am completely confused!!
    What is the difference?? I thought a MyGig was the same as a REC???
    The unit I have a line on is a OEM NAV from a 2007 300 SRT8.
    :D
    Jon (Posse)
    Jun 2009
    Ah!!!
    After doing some more reading I have found out what I didn't know!! LOL
    Yes I am looking for a MyGig NOT a REC!
    :D
    Posse
    Jan 2008
    REC is not a MyGig.The MyGig is RER or REN.They both have touch screens.RER has nav and REN does not
    LX HEMI's Avatar
    LX HEMI is offline RIP Magnum R/T
    Virginia Beach, VA
    but if you want a REC I have one for sale.
    R.I.P 05 Maggie RT
    Welcome 05 Z71
    CAI, MT's 35's, ProComp 18's, 6" Lift
    06 Harley custom, chopped, dropped and jockied
