Results 1 to 4 of 4
    smokey0810's Avatar
    smokey0810 is offline LX Padiwan
    Need Help ASAP With Subwoofer Wiring...
    Alright...Got the AMP powered, Line Out Converter wired using 12 gauge speaker cable, and the sub is hooked to the amp...BUT, no sound.
    I have the Sub bridged to the amp....
    Using the rear input on the LOC, and have cables spliced into BOTH rear speakers...So, 4 wires total running to the LOC, and the RCA cable from the LOC to the amp...Just have NO SOUND coming from the subwoofer.
    Properly grounded, amp powers up...just no sound. Anyone have any clue...Maybe too thick of speaker wire going from the stock speakers to the LOC? Please help!!! Thanks - John
    '06 Jeep Grand Cherokee Laredo
    No Mods Yet...Some On There Way....
    SmoovC's Avatar
    SmoovC is offline M45 Maniac
    Apr 2006
    Graham, Kracka'!
    Check the level adjustment on both the amp and the LOC. If that checks out, check your sub(s). Easy way to check subs: take a Makita battery, 9 volt Energizer, whatever, disconnect subs from amp, & try "popping" subs with the battery. Or to do it right, use an VOM.
    2006 Infiniti M45: Diamond Graphite Metallic, Premium Package Option Group w/ Mobile Entertainment System, Tein H-Techs & KYB Lowered, Magnaflow Exhaust
    2000 Dodge Dakota C/C R/T: Flame Red 5.9L, 1 of 800 Produced, Belltech Lowered, 20" R/T Replica Wheels, Flowmaster Exhaust
    More pics at:
    Visit us at:
    ASU_Magnum's Avatar
    ASU_Magnum is offline I'll be back...someday
    Nov 2005
    Phoenix
    double check that your negatives are on ur negatives and ur positves are on ur positives. do u have a light on ur amp that shows there is power or are u just assuming that there is power? check ur gain and your crossover switches on ur amp and make sure you have everything set to the correct channels. and frequencies.
    2005 Magnum SXT Bright Silver - SOLD
    2006 Yamaha R6 Raven -STOLEN
    Quote Originally Posted by Zmagnum
    You are famous. You have the fat woman sittin' crack findin' Magnum
    Magnum-RT-AWD is offline 12-Volt-Guru
    Dec 2004
    Christiansburg Va
    if you have a DMM(digital multi meter) check that you have resitance(sp) on the speaker side of the LOC and that you have 12volts constant on the power wire----also have the amp hooked up and see if you have voltage(AC) on the speaker terminals.
    2005 Dodge Magnum RT AWD "Cool Vanilla"
    Pioneer Premier DEX P9
    Pioneer Premier DEQ P9
    Vifa M18WN19-04 midbass
    Vifa DX25tg-05-04 tweets
    Phoenix Gold MS1000TA
    Adire Audio Brahma MKII 15
    2.75 cubes sealed enclosure
    Adire/Ampman Revolution 1500.1D----retired for now
    SunDown Audio(prototype 1500 sub amp---quite the powerhouse)
    3500 watts of SQ!!
    http://www.sounddomain.com/ride/2112117
