Results 1 to 6 of 6
Thread: Mygig Problem
    Buz-CCC's Avatar
    Buz-CCC is offline 2008 300C Silver The Best Color
    Farmingville,NY
    Mygig Problem
    I'm running 9.715 & have tried 9.807 with same results I check off a song to delete and click done but song is still on hard drive. I can delete a whole play list no problem. Is anyone else having this problem?
    Ed,
    2008 Silver 300C/Dk/Lt Slate Int.with everything but rear ves Del 8/26/08
    Slate Slush Mats/Mopar Molded Splash Guards
    SS Pillar Trim/SS Trunk Lid Trim Led's all Int. Ext. Flasher Stop 20 led towers in tail Backup 50 watts (Bright)
    24oz Slate Mats (Hemi) DRL's Enabled
    Buz-CCC's Avatar
    Farmingville,NY
    Quote Originally Posted by Buz-CCC View Post
    Come on can someone see if they can delete a single song using above versions so I will know if its hardware or software. All you have to do is copy 3 songs from a cd then hit stop copying go in find the folder with the songs and see if you can delete just 1 song then you can delete the whole folder.
    Ed,
    snailtek is offline LX Padiwan
    Oct 2005
    Los Angeles
    what about choosing your song then hit te edit softkey and delete softkey?
    05 Silver Magnum SE <= that's all i can afford =>
    Stock! Nothing Exciting! But.. got u-connect, homelink, NAV & VES, 18" R/T wheels.
    Buz-CCC's Avatar
    Farmingville,NY
    Ok for others that had a hard time with this after you check the song you wish to delete press the button with the check mark and then press done!
    Ed,
    Manny08's Avatar
    Manny08 is offline MANNY
    Silicon Valley
    Buz, dont have my car with me today, but I will check it for you later on tonight or early in am on Wed. BTW, I have 9.715
    Darth Vagon's Avatar
    Darth Vagon is offline LX Padiwan
    Feb 2008
    Cumming, Georgia
    I'm running 9.807
    Went to edit playlist> delete file in playlist> mashed yes and the file was gone.. No Problem
    Paddle faster, I hear banjo music.......
