Originally Posted by
ZC3000
Thanks for the info fellas....I knew I'd get an answer if I posted my problem. I may have to reset it using this maintenance procedure if the problem comes back.
Yeah, this happens on my unit as well. There is always a faint audio of whatever it is you had on at the time of turning it off. I find the best way to deal with this is to put it into hard-drive mode (with no songs selected to play) prior to shutting it off.....that way there's nothing to listen to when you need absolute silence in the car.
Has there been a solution found for the faint audio issue? I'm upgrading to a RER soon, and this issue will annoy the hell out of me. I already don't like the fact that:
1)No EVIC or RER display of uconnect, phone signal strength, or battery remaining. Only phone number.
2)Factory VES is on it's own- No more radio, Sirius, or any other source shared from head unit. Only DVD on VES. No sound from VES through factory sound system. Albeit you can mod the wiring to get sound, or use the IR headphones.
3) No EVIC display of Sirius, unless you have original SDARS module with TERK SIR SP, which is basically discontinued. Try finding a TERK SIR SP now..... Even if you did, once your original subscription on your original SDARS ends, what are you gonna do? Have 2 subscriptions just for the SAT evic display?
4) Other little quirks that I've read about, such as NAV voice guidance getting cut off, Hard Dive corruption, touch screen freezing issues, ect.
I'm almost starting to regret that I took the plunge. We'll just have to see how it fares when I receive all needed to make it work. I can compromise with some of these issues, but the faint audio, and NAV voice getting cut off, will drive me insane! If it's too glitchy even after clockfix, and latest updates, I'll be posting it all as a package deal for sale, and go back to my trusty REC, which has never let me down.
VYPER883
300C... A Demon In Gentleman's Clothing...
300C SRT 8... Pure Evil Dressed to the Nine's...
"Ever notice how you come across somebody once in a while you shouldn't have ****ed with? That's me." Clint Eastwood as Walt Kowalski in Gran Torino.
