Results 1 to 6 of 6
    SMKG HOT's Avatar
    SMKG HOT is offline Finding the Line - Semper Fi
    Exclamation MyGig/Ipod interface cable? HELP Please....
    I have an 08 Nitro R/T w/ Mygig:
    I want to be able to use my ipod with the radio. Where in the hell do I get the cord to go Ipod to Mygig pin plug?
    Can I use a 3.5mm x 3.5mm jump cord to interface with? Would I be able to control it with the steering wheel controls still?
    Is there another cord that attaches to it like the Ipod/Iphone cord but with a pin plug?
    Will it charge using the 3.5 x 3.5 cord?
    I am just not a tech-ey when it comes to a/v stuff.
    Thanks for any REAL ACURATE INFO.
    Laguna Seca 1.56.24 (4-22-08) 52*F 300C/SRT8 SVS Tuned
    398.91 RWHP / 394.08 (ft/lbs) Torque - (2-21-09) N/A 6.1L Stock Heads & Internals
    SMKG HOT's Avatar
    This is what I found..........
    Cables To Go - 35508 - 4ft iPod Dock Connector to 3.5mm Cable (White)
    Hope it works........
    http://www.amazon.com/gp/product/B00...ref=cm_sp_item
    JonW's Avatar
    JonW is offline LX Flasher
    Jun 2004
    Huntington Beach, CA
    Walt, the only problem with that is you won't be charging at the same time.
    Here's one that gives you power leads and audio/video:
    http://www.crutchfield.com/app/produ...rch=ipod+cable
    The only real problem with it though is that it terminates in RCA's and you want the 3.5mm plug to go into the face of the radio. You could always use an adapter between the RCA's and the 3.5mm though.
    " Where Southern California Car Culture Meets Modern Mopar Muscle"
    UnholyOne is offline LX Newbie
    Jul 2008
    You can not control the ipod with a mygig period.
    You can of course copy the music from the ipod to the hard drive (using the USB) of the mygig to be able to use your steering wheel controls.
    xj31 is offline LX Newbie
    Jan 2008
    Quote Originally Posted by UnholyOne View Post
    Not quite. It depends on the car,but some 2008s with the REN MYGIG came from the factory with an ipod cable in the glove box that lets you control the ipod from the radio.It shows up as another tab and it works really well.2009s have that available on the RER radios.As far as adding that to an earlier model,that might not be possible,but I can't say 100% for sure.
    SMKG HOT's Avatar
    I'm still confused.............
