Results 1 to 4 of 4
    rfgervasi's Avatar
    rfgervasi is offline rfgervasi
    Sep 2007
    Long Island NY
    MYGIG installation
    I have come across a MYGIG. Will I be able to install in my 300 touring? I have a REC nav unit that I installed in there now.
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    depends..
    is it the FASTCAN or SLOCAN mygig (there are 2 different models depending on the CANBUS speed)
    your car is the SLOCAN, so it if is the SLOCAN model, then you need a wire harness because the pinouts are different.. actually I believe the entire connector is different.
    if it is a FASTCAN, then no it won't work.
    rfgervasi's Avatar
    Sep 2007
    Long Island NY
    Quote Originally Posted by Mr. iNCREDIBLE View Post
    depends..
    So I need the part number and you can decode it?
    Apr 2006
    someone here can.. I don't know the part numbers but Resumespeed does....
