Results 1 to 6 of 6
    Sal SRT-8 is offline Waiting to get blown...
    Sep 2008
    Richmond, TX
    MyGIG is Dead! 2008 Charger 9.807
    ok, this MyGiG is getting on my last nerve. I went out yesterday to my car and the myGIG is not working at all. I press everybutton (incl power) and nothing happens except the open/close button is the only thing that works. I get in this morning and still nothing. Anybody have an easy fix, dont want to go to the dealer....
    thanks!!!
    1987 Buick Grand National: GT3255A Turbo, Razor Alky Injection, and some other goodies
    2008 Dodge Charger SRT-8: 180* T-Stat, MyGIG Lockpick, Reverse "Keyhole" Camera, BT Catch Can, Anzo Red LED tails, Predator, Corsa, Magnaflow Cats, AEM A/F Ratio and Voltmeter Gauges in Saleen pod, Foose Speed 22X9, Pirelli Scorpion 265/35-22
    mlb12's Avatar
    mlb12 is online now LX Oldie
    Calgary, Alberta Canada
    Quote Originally Posted by Sal SRT-8 View Post
    thanks!!!
    I note that you have a LockPick on it. I've seen this happen occasionally with both versions of the CoastalETech product.
    Keep the ignition off, go into wherever you've got the LockPick hidden, unplug the LockPick harness from the black box itself and reset(replug) the plug. This may or may not work, but as noted, I've seen it work before.
    Good Luck.
    Sep 2008
    Richmond, TX
    Quote Originally Posted by mlb12 View Post
    I note that you have a LockPick on it. I've seen this happen occasionally with both versions of the CoastETech product.
    Keep the ignition off, go into wherever you've got the LockPick hidden, unplug the LockPick harness from the black box itself and reset(replug) the plug. This may or may not work, but as noted, I've seen it before.
    Good Luck.
    Good info, that is the first thing i will try. Do you know anything about disconnecting the neg batt cable? I read over at www.mofv.com forums that it may help also?
    Sep 2008
    Richmond, TX
    Good Luck.
    I knew i could count on someone from LXForums to come through!!!!
    That was it, i reset the Lockpick and everything is back to normal! Thanks mlb12, i really appreciate it!!!!!
    mlb12's Avatar
    You are most welcome. Remember me in your will; the spelling of the last name is.........
    In all seriousness though, that is what this Forum is all about, helping those who need it, whether they know it or not!!!!!
    pukkaSRT8's Avatar
    pukkaSRT8 is offline puk·ka [adj.] authentic, 1st class
    NW Chicago Burbs
    Good Luck.
    I second this! When all else has failed, resetting the lockpick has done the trick
