Results 1 to 11 of 11
    LP81's Avatar
    LP81 is offline Noobity Noobity Noooooob... (not really)
    Apr 2006
    Grayslake, IL
    Unhappy Light burned out on A/C Controls?
    I was unsure what sub-ection to put this under so I figured since it was part of the main console, that it should go here.
    So like the title states, I think I have a burned out bulb on the A/C Controls. I have the single climate control, not dual. The left side lights up just fine (air speed, A/C button and 1/2 the temp gauge), the right is not lit up. It's hard to find the defogger button in the dark and see where my air is being directed out.
    Does anyone know if this is simply a bulb/LED that is burned out back there or just a loose connection? The knobs function correctly so I am leaning towards a bulb. Where abouts in the control box is the bulb, and is it replaceable?
    I am very familiar with removing the cover and getting to all the stuff behind it so long as I know what I am going after/looking for.
    Thanks!
    -Patrick
    Zoban's Avatar
    Zoban is offline lil Red Wagon
    Feb 2008
    Oshawa Ontario
    The bulb is most likely and they are not the most friendly to replace as they are soldiered into the board..
    Some have changed the lights and even changed the colours though so if yer a steady hand then it's an option..
    2006 Lil Red Wagon SXT
    Modlist : AFE Stage II, JBA Headers, Corsa Catback, 20" Vipers, Cross Drilled Rotors, Diablo Bob@SVS Tuned, Pioneer DEH-5000UB, 12" Enclosers, Halos, Low/Fog HIDs, Cuda Grille, TruFiber Chally Hood.
    at the Track
    My Garage
    Mentoria Computer Consulting
    carchitect's Avatar
    carchitect is offline has been pardoned by the language filter
    Morton Grove, IL
    You'll probably have to get a new HVAC control unit as Zoban said these aren't meant to be replaced if you really want to have the lights back.
    Before going that far I would pull the bezel off and reseat the connector to make sure they didn't slip loose.
    2006 Inferno Red Charger R/T|Zoomers|C&L Intake|Retro Mag 500 Wheels|Pedders Touring Plus w/ adjustable camber|General Grabber UHP 255/55/18|Flat Black Daytona Grille|BT Catch Can|SRT-8 Rear Diffuser|Mopar Chin Spoiler
    JayR04's Avatar
    JayR04 is offline LX Padiwan
    Aug 2007
    Los Angeles
    Common problem. Happened to me. Good thing it was still under warranty.
    Mods: 20% tint, touchscreen radio, 22" rims, removed resos, smoked tails, 12" FI SSD, MTX 1000XD, PG comp. speakers.
    Check out my car
    PSN: JayR04
    smagnumrt's Avatar
    smagnumrt is offline LX Padiwan
    Sep 2009
    Winnipeg, MB
    If you do replace it dont throw out the old one
    bigrone72203's Avatar
    bigrone72203 is offline LX Padiwan
    Stationed: Manhattan Kansas- Native Of FLORIDA
    happened to me also....had to replace the whole HVAC control at the dealership
    Super T's Avatar
    Aurora, IL
    They can be replaced if you can solder. They can also be converted to led. Not exactly easy but not impossible. I'm 2/3 done doing my whole car, others have also done it. How much work do you sant to put in to save $90?
    Posted via LXFMobile
    BDA1855's Avatar
    BDA1855 is online now Ultra Heavyweight "Fatman" Race Team
    Nov 2008
    Riverside, CA
    Mine died too... you can get them brand new from Dodgeparts.com for $67
    thats for the whole unit all three dials... not too bad...
    2006 INFERNO RED MSRT8 - SOLD-
    WWW.MOPARSYNDICATE.COM
    LP81's Avatar
    Apr 2006
    Grayslake, IL
    Well i took the car in today for other stuff and had them check if it was under warranty, and it was... I go to cash out and they tell me $133. Apparently even thought it was covered by the warranty, I still had to pay a $100 deductible... Jeez... I should have just bought it myself and swapped it out. Live and learn... Of course the new one looks a little out of place too because it has the silver edges to the knobs while the REC is all matte finish... oh well...
    -Patrick
    johnmilza's Avatar
    johnmilza is offline LX Newbie
    Apr 2008
    Queensbury, NY
    Half of my lights are out on HVAC panel. Went to dodgeparts.com website. 2 units listed w or w/o atc. What is atc?
    https://www.dodgeparts.com/oe_parts_...5799ad7f3c8bfc
    I also had gauges freak out and go to zero today - twice. Went back to normal after restarting car. Wonder if they are related? hmmm....
    2006 Magnum R/T AWD, Mopar Performance CAI, Hurst Shifter, SLP Loud Mouth Exhaust
    johnmilza's Avatar
    Apr 2008
    Queensbury, NY
    atc
    duh - atc = automatic temperature control
