any have any suggestions on what sub I can use to replace the factory woofer. I like the encloseure but would like a little more bass then that gives. I will be useing a rockford 800a2 amp...all suggestions weclomed
go with art of sound sub box... man it sounds great with my rockfrod p3 punch's... i am using that amp right now.......
sorry little drunk!
kevin
I think Kevin meant Art of Noise, Robbyho is the LX member making the awesome boxes Kevin is referring to. Mine sounds SWEET!
05 "Shagwagon" R/T
Go USF Bulls!
Hemi Registry #000514
I replaced mine with this:
I do not believe that you can actually re-use your Kicker box with another speaker, so you'd have to look at other enclosure options.
lol at kevin up above.
You might be able to replace the kicker sub. Can you get at it or is it installed in a weird way, like from the inside or with a plastic turn and lock sysem?
If you can remove it, then all you have to do is figure out the mounting diameter and the depth, then get a replacement sub.
However, you have 800 watts available to you and that enclosures is *most likely* abs plastic. Probably will rattle and flex with a powerful sub. You can have an MDF box built for about $50, I've seen 3/4" mdf enclosures at the flea market for $25, so cost isn't even a factor.
Or, you can always get one of my enclosures.
Rob
I do it's (FromUndaCheezz) send me an invite. Also how much fo rthe enclosure?
Will do. My GT's are Stopbeing Angry and B675309 in case anyone else wants to send me an invite.Originally Posted by halo2
The enclosures are $325 each and $550 for the pair. That includes covering them in whatever you want, such as carbon fiber, color matched vinyl, suede, carpet, lizard skin, whatever, etc. It also includes shipping to the main 48 states.
Rob
