Results 1 to 10 of 10
    1sthemi's Avatar
    1sthemi is offline LX Newbie
    May 2006
    Installing rfid alarm..need wire specs..HELP!
    Hi i just purchased this alarm from ebay and wanted to install it http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=400003435346
    I was wondering could some one tell me the basic wire color and what they are for to install this on.... I know that the ground is black and the 12vlt is red but i need help with the wires for the unlock buttons and etc
    SPguy82 is offline LX Padiwan
    Jan 2007
    Oxford,PA
    the12volt.com has it. you will need relays for the resisted locks, get the parking light wire from the passenger side or you will need relays at the switch as well since lights are multiplexed.
    1sthemi's Avatar
    May 2006
    ok i found some of the wire but i cant find the door trrigger wire in the pilar because theres nothing there and i cant find the wires for the unlock and lock buttons....do anyone know how to install the resistors on the lock /unlock wires
    sound&security's Avatar
    sound&security is offline NOT MADE IN CHINA!
    Aug 2007
    FT LAUDERDALE
    the door trigger is on the passinger side A-pilar up high and changes color when it comes down to the kick panel on some LX'S I HAVE FOUND. IT'S yellow with a white stripe. but using this wire WILL give you a signal that your door is open because of the delayed lighting. SO this means that when you arm the system it will give you extra chips from the siren because it will think the door is still open. THIS isnt a problem/when the lights go out the system will be armed. your parking lights are in the passinger side kick also UP HIGH AND TOWARD's the fire wall and are looking for a positive trigger. no relay needed.
    Think about how stupid the average person is..
    Then realize half of them are dumber than that
    Aug 2007
    FT LAUDERDALE
    the door lock/unlock wire is ONLY ONE!! IT's in the drivers side kick panel in a gray 26 pin plug-the color is purple with a dark green stripe-its in pin location# 5. YOU'LL need 2 relays for this. on the relays you will see numbers next to the male pins-both pin's #86 get attached to 12 volt power with a 15 amp fuse. next both pins #87 go to a ground point on the car under the dash. NEXT YOUR DOOR LOCK/UNLOCK WIRES from the alarm go to pins #85 on the relays. [blue on one relay and green on the other] The center pin on the relay's [#87a] dont go to any thing and will not be used. LAST part-on pin#30 on both relays you will connect wire about 6 inchs long or so [one on each pin #30] then strip the end of each. next you will use a red butt connector on each striped end. Now you need a 330 ohm resistor and a 100 ohm . place one of the resistors in the end of the butt connector and crimp it down. do the same thing with the next resistor on the other open butt connector. Now place a red butt on the other ends of the resisitors and crimp. NEXT strip 2 more lenghts of wire [12 inchs or so so you have length to work with -HEHE THATS WHAT THE GIRLS SAY-] AND GRIMP them into the open ends of your 2 red butt connectors. THIS will leave you with 2 lenghts of wire runing out of your relays off pin #30. BOTH of these wires togther get tapped to the said door lock/unlock wire together which again is purple with a dark green stripe in driver's kick in the gray 26 pin plug -pin#5
    1sthemi's Avatar
    May 2006
    Yea i found it but now im having a problem getting them to work from the remote...i think something in connected wrong but thats exactly what i did above.....
    Aug 2007
    FT LAUDERDALE
    the resistor value is wrong then. 330ohm and 100 ohm is just a starting point and works on MOST lx's BUT NOT ALL-
    1sthemi's Avatar
    May 2006
    Ok the resistors are the correct ohms but someone told me i needed a relay aswell so im gonna put that in today and check back with you to let you know..thanx!
    Aug 2007
    FT LAUDERDALE
    dude!!! you need 2 relays!!!! look up 4 reply posts and i explained how to do it. [not being a wise a$$] hope it works out.
    1sthemi's Avatar
    May 2006
    my bad i didnt mean to say that above.....i did as you told me but i think im not geting any power out of the alarm for the lock/unlock...ima just return it and get a new one and hopefully that works
