Results 1 to 4 of 4
    SV Cat is offline SV Cat
    Sep 2007
    Sierra Vista, AZ
    Help W/ Decision
    I just recently got a Kenwood KAC-7204 w/ the following specs: http://ae.kenwood.com/Car_Entertainm...fiers/KAC-7204
    I am looking to do a SQ setup in a sealed box according to optimal size with the following subs.
    I need input as to what the best setup with this amp is:
    2-10" MB Quart RWE-252
    Peak Power Handling: 600 watts
    RMS Power Handling: 300 watts
    Frequency Response: 22 300 Hz
    Subwoofer Size: 10"
    Impedance: dual 2 ohms
    Possible Impedance Variations: 1, 2 or 4 ohms
    Recommended Box: 0.65 cu. ft. sealed
    Sensitivity: 2,4dB
    Mounting Depth: 5.2"
    or
    1- 12" MB Quart PWH 304
    12" Dual 4 ohms Premium Series Subwoofer
    Power Handling:
    Peak: 1000 watts
    RMS: 500 watts
    Impedance: Dual 4 ohms
    Injection polypropylene filled, honey cone structured body with WPC titanium wet powder coating
    1" Wide rubber surround
    "Wrap Around" die-cast aluminum basket and motor structure with diamond-cut machined sides
    Finite element analysis linear flux saturated magnetic plates with chrome finish
    Single flat Conex spider with woven tinsel leads
    Polypropylene dust cap with hot-stamped MB Quart logo
    3" Voice coil on glass fiber former with aluminum reinforcement on neck
    120oz. Double stacked ferrite magnet
    Frequency response: 32-380 Hz
    Sensitivity: 85 dB
    SV Cat
    MagnumRT05's Avatar
    MagnumRT05 is offline ***Drop Beats, Not Bombs***
    Jan 2007
    Westlake, Ohio
    Any better specs on the subs?
    Sealed enclosures arent always best option for SQ setups. Mainly used for subs with high Qts or if you dont have room whatsoever. I would personally go with the (2) 10s in a 4th order ported enclosure. Bet it would sound pretty nice and you have the room for it.
    -392 Twin TC70 Turbo Build
    BlackCharger06's Avatar
    BlackCharger06 is offline Black Charger 06
    Boston
    yup pretty much
    Quote Originally Posted by MagnumRT05 View Post
    You go with a sealed if space is an issue and you actually need a truck in your everyday life Ported will really give you some pop. Have you looked at other subs/amps. I'd head over to caraudio.com or diymobileaudio.com and do some more homework. They sub/amp you listed will get the job done, you just have plenty of other options. I've got a 10w7 and by no means is that the best sub, but it does the job for my small system.
    <img src=http://i84.photobucket.com/albums/k8/brian_pahlm/wheels/new_england.jpg border=0 alt= />
    Audio Mods
    Alpine Iva W205 w/ 6 disc changer Alpine pxa-h701 Processor JL audio 450/4 JL audio 500/1 JL audio 10w7 Boston Acoustic SL95's Hertz MLk 2 Componets PowerMaster d3100
    Other mods
    Hood Strut Mod Daytona Grille R/T BadgesRetro Charger Deck Badge Ct Cruzer (Blastin Bob's) Custom Exhaust, What's next????
    Sep 2007
    Sierra Vista, AZ
    Sealed Setups
    The reason why I am trying to go with a sealed setup is because I am limiting myself in that I want to put the 2 10" subs or 1 12" in the floor. I don't want a big box in the rear hatch nor do I want to spend as much on the side enclosures that are being sold in other places.
    Thanks for the input though!
    SV Cat
